查看: 38221|回复: 0
[技术] Ayaic Mix Monolith v0.5.1 WIN 自动混音系统
发表于 2021-7-24 14:27:17 | 显示全部楼层 |阅读模式
一种独特的混合方法The Mix 单体是 Ayaic 的另一个行业首创。它是一个“自动混音系统”,可让您在任何环境中完美地调平您的混音。从单个轨道到总线组,到 FX 通道,再到您的主推子,Mix Monolith 将创建一个平衡且只需单击按钮即可打开的混音。
还有(无限)Duck/Expand Groups 以及(无限)Mute Groups 可以帮助您以前所未有的方式清理混音中的空间。闪避非常精确,如果您的低音吉他需要 -3dB 的闪避,这正是您每次敲击底鼓时都会得到的。成组使用闪避让您可以将底鼓浸入低音、头顶、底鼓氛围、音乐总线并将整个混音全部集中在一个组中……而且一切都完美无缺。使用人声来降低人声混响和延迟,同时扩大一些坚韧不拔的人声失真,以增加对更响亮的人声段落的态度。有了这么多 Duck/Expand 组,您将能够在几分钟内创建令人兴奋的混音。与我们的“Ceilings Of Sound Pro / Hyper-EQ”搭配使用时,您将能够比以往更快地将元素放入混音中。只需将 Hyper-EQ 与有趣的新天花板形状相匹配,然后使用 Monolith 上的 LEARN/MIX 功能立即听到它们在混音中的表现。免费试用 Mix Monolith 7 天,第一次将它应用到任何一个混音时都会被震撼。
Mix Monolith 针对具有大量轨道数的项目中的多个实例进行了优化,其控件非常直观,允许您快速调整参数或输入值。
The Mix monolith is another industry first from Ayaic. It is an “Automatic Mixing System” that allows you to level your mixes perfectly in any environment. From individual tracks, to buss groups, to FX channels, to your master fader, Mix Monolith will create a mix that is balanced and open with just a click of a button.
There are also (infinite) Duck/Expand Groups as well as (infinite) Mute Groups to help you clear space in your mixes like never before. The ducking is so precise that if you need -3dB of ducking for your bass guitar that’s exactly what you’ll get every single time the kick drum hits. The use of ducking in groups allows you to have the kick drum dip the bass, the overheads, the kick ambience, the music buss and pump the whole mix all within a single group…and all perfectly. Use the vocals to duck the vocal reverb and delay while simultaneously expanding some gritty vocal distortion to add attitude to the louder vocal passages. With so many Duck/Expand groups you’ll be able to create exciting mixes in minutes. When paired up with our “Ceilings Of Sound Pro / Hyper-EQ” you’ll be able to place elements into a mix faster than ever before. Simply conform the Hyper-EQ to interesting new ceiling shapes then immediately hear how they sit in the mix using the LEARN/MIX feature on the Monolith. Try the Mix Monolith for 7-Days FREE and be blown away the very first time you apply it to any one of your mixes.
https://plugincrack.com/plugins/ayaic-mix-monolith-0-0-11-win/
Mix Monolith is optimized for multiple instances during projects with large track-counts and its controls are intuitive, allowing you to quickly adjust parameters or type in values.
GMT+8, 2025-6-3 04:22 , Processed in 0.030029 second(s), 10 queries , Redis On.
