查看: 25088|回复: 0
[其它产品] Rossum Electro-Music Satellite 音序器 合成器模块
发表于 2021-3-23 12:21:12 | 显示全部楼层 |阅读模式
Satellite是一个紧凑的12HP模块,可以加载来自Rossum Electro Music Control Forge或其他卫星的所有(或子集)预设和预设序列,然后作为一个完全独立的CV发生器工作。一旦预设和预设序列从另一个模块传输(通过跳线连接),卫星就不再需要与该模块进行任何连接。使用一个或多个卫星,您可以利用您的所有控制锻造预设和序列在多个机柜甚至不同的系统。
多个卫星可以从同一个控制中心编程,并通过它们的门输入同步在一起,以创建复杂的合成音序列和调制轮廓。除了与Control Forge或其他卫星直接连接外,预置和预置序列也可以通过Control Forge或Satellite保存的音频文件档案进行加载。由于这些文件可以在线发布和下载,这是一个分享和交换预置的好方法。
卫星规格预置500个预置序列200个序列步数20000个动态分配输入门/触发器1x 3.5mm单声道插座 Satellite is a compact 12HP module that can be loaded with all (or a subset) of the presets and preset sequences from a Rossum Electro-Music Control Forge or other Satellite and then function as a completely stand-alone CV generator. Once the presets and preset sequences are transferred from the other module (via a patch cord connection), Satellite no longer requires any connection to the module. With one or more Satellites, you can take advantage of all of your Control Forge presets and sequences in multiple cabinets or even different systems. Multiple Satellites can be programmed from the same Control Forge and synced together via their Gate inputs to create complex polyphonic sequences and modulation contours. In addition to direct connection with a Control Forge or other Satellite, presets and preset sequences can also be loaded via audio file archives that have been saved from a Control Forge or Satellite. And since those files can be posted online and downloaded, it’s a great way to share and exchange presets. Satellite Specifications PRESETS 500 PRESET SEQUENCES 200 SEQUENCE STEPS 20,000 Dynamically Allocated INPUTS Gate/Trig   1x 3.5mm mono socket
100kΩ Input Impedance
1.6V threshold Logic  1x 3.5mm mono socket
1.6V threshold CV 1  1x 3.5mm mono socket
-5V to +5V CV 2  1x 3.5mm mono socket
-5V to +5V CV 3  1x 3.5mm mono socket
-5V to +5V CV 4  1x 3.5mm mono socket
-5V to +5V Time Scale CV  1x 3.5mm mono socket
-5V to +5V Preset Sequencer Dec 1x 3.5mm mono socket
1.6V threshold Preset Sequencer Inc 1x 3.5mm mono socket
1.6V threshold Preset Sequencer Reset 1x 3.5mm mono socket
1.6V threshold OUTPUTS + Output 1x 3.5mm mono socket
<1Ω Output Impedance
-5V to +5V – (Inverted) Output 1x 3.5mm mono socket
-5V to +5V Trigger 1   1x 3.5mm mono socket
1kΩ Output Impedance
10V
Selectable Width Trigger 2 1x 3.5mm mono socket
10V
Selectable Width POWER REQUIREMENTS +/-12V via 16-pin, Doepfer-style connector CURRENT DRAW 125mA +12V, 25mA -12V (maximum) DIMENSIONS 12HP (W); Panel to power connector (with connector plugged in) 25mm (D) SUPPLIED ACCESSORIES 1x 16-pin, Doepfer-style cable
4x M3 screws
4x M2.5 screws
4x Nylon washers
1x Quickstart Guide View or download Satellite documentation.  (PDF)
GMT+8, 2025-5-30 12:56 , Processed in 0.029570 second(s), 10 queries , Redis On.
