查看: 28659|回复: 1
[软件] HDMI音量控制软件 – Sound Control 2.5.0 MacOS
发表于 2020-8-6 08:49:44 | 显示全部楼层 |阅读模式
9 D0 w" T, u% r
$ V& P, h) S3 s, e( j
9 O7 R3 V: l, p" }9 E1 o. v9 W7 DSound Control Mac版是Mac平台上的一款HDMI音量控制软件,Sound Control Mac版是一个可以帮助用户独立调整和控制每一个App音量的均衡器。
4 d5 h. s! [9 o+ D! T
0 q: y1 Y2 U8 D# `File size: 6.1 MB0 Y( ?$ C$ n  S
Sound-Control (1).png + e2 P- c" Y& z$ ^/ l3 v
Sound Control lets users use a software volume mixer. Sound Control enables users to easily and quickly change app volumes as well as selectively apply a system-wide EQ to app audio. Sound Control does this by adding a software mixer to the menu bar of your Mac. In addition to the volume mixer, Sound Control also adds a software EQ to your audio output allowing users to easily tailor the sound of their Mac’s audio to their specific taste or to properly calibrate to the frequency response of their speakers.
/ J$ o. a$ w1 B4 d% A
  P6 j! P) a; l' i3 FFeatures
8 C& A" \5 g  x$ o" g7 x: n6 z
! Q8 R5 `! C) h$ _- j) _: uPer-app volume control, including mute
, E8 S! [0 I7 d7 W! q" [- k% L
/ z* u8 e5 D7 H+ NSystem-wide EQ with 10 or 31 bands
" c3 [( p+ x; N. C) ]& ]2 n
( ]7 C) B$ F  }, E. GEasy control via menu bar item or hotkeys
6 `! `9 Q6 d; Y5 i$ u% d. u- ^# u+ P. H( X3 r6 A* [* J& ~3 `
Add software and keyboard control to HDMI and other audio devices' R8 @' j9 G8 ]/ @2 Y7 h4 f. e
$ }0 F+ w6 d# [# ]Requirements: Intel, 64-bit processor OS X 10.10 or laterRelease Notes: O0 F% l2 {4 I1 A# y7 V' y5 m
) j0 C/ V: a5 z2 b4 l9 R8 k Sound_Control_2.5.0_[HCiSO]_.zip (5.63 MB, 下载次数: 0)
98
发表于 2020-8-25 07:19:05 | 显示全部楼层
谢谢楼主,十分感谢
GMT+8, 2025-7-22 04:56 , Processed in 0.031650 second(s), 11 queries , Redis On.
