查看: 42878|回复: 1
[效果器] Tonstrum TRAVELER v1.1.2 [WiN]多普勒效果器
发表于 2020-6-26 23:15:28 | 显示全部楼层 |阅读模式
旅行者精确地模型的声学现象的多普勒效应,与强大和直观的图形路径编辑器,以确定声音的虚拟运动。多普勒频移的一个常见例子是当车辆发出喇叭声接近或远离观察者时听到的音高变化。
旅行者具有一个完全成熟的2D路径编辑器,允许您精确地形状的声源的运动路径。此外,还可以根据路径自由地定位侦听器。
旅行者提供了直观的控制速度的声源,路径长度和总多普勒路径持续时间。
旅行者也有一个板载循环和颗粒样播放器。颗粒样播放器允许同步播放到多普勒路径。这使得它有可能在不同的持续时间播放所需的声音效果,同时保持一切在完美的同步。
费力地建模和物理精确多普勒频移、距离增益和空气吸收滤波的高精度建模。全64位处理精度。
图形2D运动路径编辑非常详细的虚拟运动编辑。根据路径自由地定位听众。
强大的样本回放引擎具有清洁和纯循环样本回放和先进的同步颗粒样本回放。
设计适合所有可想到的场景作为现场插入效果,并提供增强的音频套件功能。拖放或现场记录你自己的声音。精确同步多普勒路径在时间码,秒或棒&拍模式。
先进的后效果和调制可能与5后效果和4自由分配的多段LFOs。使你的调制与多普勒路径同步。
带有音响效果和预置,有超过80预置和样本,作为理想的起点,探索巨大的创造性潜力的旅行者。
主页:
https://tonsturm.com/software/traveler/
TRAVELER precisely models the acoustic phenomenon of the Doppler effect, with a powerful and intuitive graphical path editor to determine a sound’s virtual movement. A common example of Doppler shift is the change of pitch heard when a vehicle sounding a horn approaches and recedes from an observer.
TRAVELER features a fully fledged 2D path editor allowing you to precisely shape the motion path of the sound source. Further it is possible to freely position the listener in relation to the path.
TRAVELER offers intuitive control over the speed of the sound source, path length and the overall doppler path duration.
TRAVELER also comes with an onboard loop and granular sample player. The granular sample player allows synchronized playback to the doppler path. This makes it possible to playback the desired sound effect at different durations while remaining everything in perfect sync.
Painstakingly modeled and physically accurateHighly accurate modeling of doppler shift, distance based gain and air absorption filtering. Full 64-bit processing precision.
Graphical 2D motion path editorVery detailed editing of virtual movement. Freely position the listener in relation to the path.
Powerful sample playback engineFeatures clean & pure loop sample playback and advanced synchronized granular sample playback.
Designed to fit all thinkable scenariosWorks as live insert effect and offers enhanced Audio Suite functionality. Drag & Drop or live record your own sounds. Precisely synchronize the doppler path in timecode, seconds or bars & beats mode.
Advanced post effects and modulation possibilitiesComes with 5 post effects and 4 freely assignable multisegment LFOs. Synchronize your modulations in sync to the doppler path.
Comes with sound effects and presetsComes with over 80 presets and samples serving as ideal starting point to explore the vast creative potential of TRAVELER.
home page:
Team R2R | 11 May 2020 | 248.4 MB
GMT+8, 2025-7-18 13:32 , Processed in 0.041392 second(s), 10 queries , Redis On.
