查看: 57985|回复: 1
[插件] 经典的Urei 1176压缩器 Pulsar Audio Smasher v1.0.3 WiN
音频应用推广专员
Rank: 2Rank: 2
发表于 2020-6-22 13:04:30 | 显示全部楼层 |阅读模式
Smasher是对经典Urei 1176压缩机电路的前所未有的定制修改,这是我们在微调其他算法时偶然发现的独特公式。
最初的1176压缩机硬件提供了四个比率的选择,但是录音室工程师很快发现,一次按下所有比率会导致失真,爆炸和高度压缩的声音。 Smasher精心设计的正是这种“所有按钮处于”或“英国”模式。
在保持与原始电路非常接近的同时,我们对Smasher进行的修改将为瞬变添加清晰度,并使您的音色更具侵略性。我们喜欢用它来增强鼓式公共汽车的氛围,但是还有更多的创造性用途。 Smasher不会在所有单曲上都起作用,但是它在哪里都能发挥作用。
Smasher擅长于原始声音和坚韧不拔的声音,吸引了Vulfpeck,Whitefield Brothers和Black Keys等乐队。
Smasher is an unprecedented custom modification of the classic Urei 1176 compressor circuit, a unique formula that we stumbled upon while fine-tuning other algorithms.
The original 1176 compressor hardware offered a selection of four ratios, but studio engineers soon discovered that pressing them all at once led to a distorted, explosive and highly compressed sound. It’s this “All buttons in” or “British” mode that Smasher was painstakingly designed to recreate.
While remaining very close to the original circuitry, the modifications we’ve built into Smasher will add definition to transients and make your tone more aggressive. We love using it to enhance the ambience in drum busses, but there are many more creative uses too. Smasher won’t work on every single track, but where it does, it works magic.
Smasher excels at raw and gritty sounds, calling to mind bands like Vulfpeck, The Whitefield Brothers and The Black Keys.
* No iLok Driver is required to run.
* Our release loads faster and uses less memory than original.
FIXED :
Previous release fades and beeps.
Pulsar Audio put new bomb based on the PACE Fusion crypto. It looks nice and can stop most static value modification attack by most crackers. Anyway, those most crackers cannot unpack current WrapWarden – we think that bomb is just another CPU waster once cracker found the issue.
Thanks to our custom injected code, our release does not do cyclic iLok access and content decryption like legit one 🙂
https://www.4download.net/913-pu ... r-full-version.html
Home Paqe – https://pulsar.audio/smasher/
56
发表于 2021-8-15 19:46:40 | 显示全部楼层
很不错的插件,我一直在找
GMT+8, 2025-6-11 06:00 , Processed in 0.024981 second(s), 8 queries , Redis On.
