查看: 25478|回复: 1
[音视频] Algoltek安格产品选型|AG安格科技|转HDMI|转VGA方案|Algoltek代理商
发表于 2020-6-16 11:37:38 | 显示全部楼层 |阅读模式
Algoltek安格科技主要提供各种格式的视频转换的整体解决方案,例如MHL,HDMI,VGA,DisplayPort,Type-C ALT模式,广泛应用于在设备和信源设备之间切换/分离视频信号的ASIC解决方案,安格瑞科技代理ALGOLTEK产品,提供全程技术资料。
Algoltek安格产品线选型表如下:
Product P/N
Application
Product  Description/ Resolution
MP Schedule
Downloa
AG6111
MHL to HDMI  Converter
※ Compliant to MHL2.2 and HDMI1.4b
MP Now
※ Resolution and Frame Rate:
- 1080p 60 frame
- 3D as 1080p 30 frames in Packed  pixel mode
AG6200
HDMI to VGA  Converter
※  Compliant to HDMI1.4b and VESA VSISTM V1.2  Standard
MP Now
※ VGA Resolution: 1920X1200@60Hz
AG7110
HDMI 3:1  Switch
※ 3-In to 1-Out Switcher
MP Now
- Support 340 MHz pixel clocks
- Compatible with 36-bit deep color
AG7111
HDMI 3:1  Switch
MP Now
AG7120
HDMI 1:1  ReDriver
MP Now
- Support 4K2K@30Hz, compatible with  36-bit deep color
AG6300
DP to VGA  Converter
※ Embedded 16 bit MCU
New Launch
※ External SPI flash supported for firmware upgrade
※ Down Spread Spectrum Clock (SSC) supported
※ On-chip HDCP1.4 Key Integrated
※ Support I2S stereo audio interface
AG6310
DP to HDMI  Converter
New Launch
AG6320
DP to HDMI/VGA  Converter
New Launch
AG9300
USB Type-C to  VGA Converter
※ Type-C DP ALT mode supported
New Launch
AG9310
USB Type-C to  HDMI Converter
New Launch
AG9320
USB Type-C to  HDMI/VGA Converter
New Launch
2750
 楼主| 发表于 2020-12-24 18:33:37 | 显示全部楼层
安格AG代理商现货,专业处理TYPEC音视频数据转换方案,安格瑞提供完整设计资料及技术支持,欢迎咨询Q:1540182856
GMT+8, 2025-6-4 00:02 , Processed in 0.036572 second(s), 10 queries , Redis On.
