查看: 34035|回复: 0
[音箱设备] 渔夫 FISHMAN LoudBox Artist PRO-LBX-600 120W 原声吉他音箱
发表于 2019-12-1 18:13:17 | 显示全部楼层 |阅读模式
The Loudbox Artist is an evolution in acoustic amplifiers. It leverages the award-winning design of the Loudbox 100, yet packs more power and enhanced features into an incredibly lightweight and portable package.
120 watts of ultra-clean, bi-amplified acoustic power, two versatile input channels featuring Fishman\'s legendary tone and feedback-fighting controls, plus a new dual effects section make the new Loudbox Artist the ultimate portable acoustic instrument amplifier for the seriously active musician.
FEATURES:
Two mic/instrument channels accept 1/4” or XLR sources
Input channels feature 3-band EQ and feedback controls
Auxiliary stereo input with level control and 1/4” & 1/8” connectors
Dual digital effects section, with independent channel & effects level
Reverb, Chorus, Flanger, Delay, Echo, and Slap Echo
D.I. output: balanced XLR outputs on each input channel and main mix
Channel Mute to silence both input channels
Headphone output
Foot Switch input for remote muting of Input Channels or Chorus, Flanger, & Slap Echo
Dual Foot Switch (ACC-LBX-FSW) sold separately
Loudbox Artist Slip Cover (ACC-LBX-SC1) sold separately
INSTRUMENT/MIC CHANNELS:
Combination 1/4” & XLR input
Resonant-style bass and midrange
Shelving treble
Notch filter (feedback control)
Input gain with 10dB pad and clip indicator
Reverb and Delay effects level
Chorus, Flanger and Slap Echo on/off
Phase switch (feedback control)
Dedicated effects loop
24V phantom power for condenser mics
SPECS:
Power: 120 Watts, bi-amped
Drivers: 8” woofer, 100W; 1” soft dome tweeter, 20W
SPL: 112dB SPL @ 1 meter
Speaker Baffle: 10o built-in tilt
Dimensions: 13.5”H x 15.5”W x 11.5”D (34.3cm x 39.4cm x 29.2cm)
Weight: 25.5lbs (11.6kg)
指导价 ¥4999
GMT+8, 2025-6-6 22:34 , Processed in 0.023957 second(s), 8 queries , Redis On.
