Output Analog Brass and Winds KONTAKT
经典吹奏。模拟铜管和管乐器是一个虚拟乐器的人敢于通过模糊强大的管弦乐声音和传奇合成器之间的界限,打破传统的400年传统,为您提供下一个级别的曲调。
逐一记录
大的braams,坚韧的音质,渴望的跑步混合在一起给你最好的组合。通过这个引擎的管道和阀门,了解输出的非常规声音设计是如何流动的。
乐队
我们在布达佩斯令人惊叹的BMC大厅采样了18件铜管部分,18件管乐器部分和手选独奏家。捕捉当代刺,扑,颤音和不寻常的技术。
合成器
你会知道他们的名字。传奇的,现代的,令人垂涎的合成器被挑选为他们的铜管和管乐器的特征。通过现场乐器,修补程序可以激发大胆的新纹理,这几乎是不可能的。
创作的
粗犷和奇异的音色融合了铜管和管乐器,让你的声音更加激动人心。试试我们从意外来源设计的标志性自定义声音。
它需要勇气
把这些声音弯曲到你的意愿。迄今为止我们熟悉且最直观的界面符合新的来源材料。一个易于使用的工作流程,通过内置高级调制布线,双磁带循环器,双琶音器,通量序列和四个宏指令滑块,为所有轻快的声音注入新的活力。
特征
500多个预设即时可玩性
28 GB声音库(14 GB压缩)
同步到节奏
强大的双层引擎
带智能标记的预设菜单
Layer FX和全球FX
4个中央宏指令滑块,每个预设都是唯一的
双琶音器
内置帮助菜单
需要Kontakt 5完全版或Kontakt免费版本5.7.1
原文
Throw classics to the wind. Analog Brass and Winds is a virtual instrument for those who dare. Breaking from 400 years of tradition by blurring the line between powerful orchestral sounds and legendary synths to give you next level air.
Blow-by-Blow
Big braams, gritty textures, wistful runs blend together to give you the best possible combinations. Get to know how Output’s unconventional sound design flows through the pipes and valves of this engine.
Orchestra
We sampled an 18-piece brass section, 18-piece wind section, and hand-selected soloists at the stunning BMC Hall in Budapest. Capturing contemporary stabs, flutters, trills and unusual techniques.
Synths
You’d know them by name. Legendary, modern, highly coveted synths were picked for their brass and wind-like characteristics. Patches were fashioned to inspire bold new textures that are near impossible with live instruments.
Creative
Bold and bizarre timbres fuse with brass and winds to give your sounds extra zest. Experiment with our signature custom sounds designed from unexpected sources.
It Takes Guts
Bend these sounds to your will. Our familiar and most intuitive interface to date meets new source material. An easy-to-use workflow made to breathe new life into all airy sounds with built-in advanced modulation routing, dual tape loopers, dual arpeggiators, flux sequencing, and four macro sliders.
Features
500+ Presets for instant playability
28 GB sound library (14 GB compressed)
Syncs to tempo
Powerful dual-layer engine
Preset menu with smart tagging
Layer FX and global FX
4 central macro sliders unique to each preset
Dual arpeggiators
Built-in help menu
Requires Kontakt 5 Full Version or Kontakt Free Version 5.7.1
Output Analog Brass and Winds KONTAKT | 14.1 Gb
下载地址:
