查看: 21291|回复: 2
[音源] Sample Magic Klip v1.0.5 KONTAKT
1万
发表于 2010-4-12 15:29:52 | 显示全部楼层 |阅读模式
Klip是一种强大的乐器和鼓机,推动了电子音乐生产的门槛,利用广泛的参数编辑矩阵和综合混音功能。
捣碎循环,重新塑造和合并节拍,撕碎节奏,节目以完全独特的时尚-所有实时-节奏,关键和节拍同步到您的主人DAW。
拼接环段,添加卷积混响,延迟,钻头破碎机,滤波器和磁带温度模拟。混合在Klip的8通道混频器与EQ,压缩,失真,瞬态设计师,buss限制器和更多。
跨越1000多个样本,跨越不同的流派,风格和节奏-深入到一个巨大的档案样本魔术的目录与多年的声音设计专业知识综合在一个仪器。
使用MIDI或鼠标实时记录、编程、播放和调整pad、控件、CC参数和synth部件。
配合您的节拍,仔细整理和专业记录模拟合成器波形包括在克利普的强大的声音库。
单击鼠标,复制序列,每个预置和MIDI注释导出最多8个模式。
完整的本地仪器Komplete Kontrol和Maschine集成提供了许多工作流微调和定制映射控件。
原文
Klip is a powerful instrument and drum machine that pushes the threshold of electronic music production, utilising an expansive parameter editing matrix and comprehensive mixer functionality.
Mash loops, re-mould and merge beats, mangle rhythms, programme in a completely unique fashion - all in real time - tempo, key and beat synced to your host DAW.
Splice loop segments, add convolution reverb, delay, bit crusher, filters and tape warmth emulation. Mix in Klip’s 8 channel mixer with EQ, compression, distortion, transient designers, buss limiter and much more.
Spanning 1000s of samples across a wide variety of genres, styles and tempos - dive into a vast archive of Sample Magic's catalogue with years of sound design expertise rolled into one instrument.
Use MIDI or mouse to record, programme, play and tweak pads, controls, CC parameters and synth parts in real time.
Complement your beats with carefully collated and expertly recorded analogue synthesiser waveforms included as part of Klip’s powerful sound library.
Copy sequences at a click of a mouse, with up to 8 patterns per preset and MIDI note export.
Full Native Instruments Komplete Kontrol and Maschine integration giving numerous workflow tweaks and custom mapped controls.
Features:
A powerful sound library with over 4000 high quality Sample Magic samples, pooled from a vast range of titles across Electronica, Techno and House
Vast variety of presets from leading Sample Magic sound designers
Unique ‘FX’ matrix allowing independent manipulation of up to 16 parameters per pad, across 32 steps
20 Filter types across High Pass, Low Pass and Band Pass
70 Lane presets for quick, enhanced pattern writing and effect manipulation
Multiple FX types including Distortion, Saturation, Bit Crusher, Delay and Convolution Reverb with flexible routing options
Powerful dynamics processing including Compression, Limiter and Transient Shaper
Warm, characterful 3-band EQ per mixer channel
8 Independent mixer channels, each of which can be custom assigned to its own output
Unique Convolution Reverb algorithms recorded at some of the world’s finest spaces
Up to 8 Sequences in each pattern, with easy copy and paste shortcuts.
Full Native Instruments Komplete Kontrol(TM) and Maschine(TM) integration with extensive MIDI CC implementation
Drag or export pattern lane to MIDI functionality
Transpose and timestretch all sounds and loops to the native key and tempo of your DAW
Playback swing to mimic classic, timeless dance music grooves and sequencers
Effortlessly record pad movements or input steps using MIDI devices
Randomise pads and preset lanes at the click of a mouse for unique, inimitable grooves
Variable grid synchronisation from 1/1 to 1/32 of project tempo for up to 32 bar patterns
In-built mixer limiter for easy, professional mixing
Extensive collection of vintage analogue synthesiser waveforms and drum hits from a host of classic rhythm boxes and keyboards
Key adjust any sound or loop key from major to minor
System Requirements
Kontakt Player 5.7.0 (Free Download) or Kontakt 5.7.0
下载地址:
游客,如果您要查看本帖隐藏内容请回复
Sample Magic Klip v1.0.5 KONTAKT| 1.33 GB
325
发表于 2010-4-12 23:15:05 | 显示全部楼层
Sample Magic Klip v1.0.5 KONTAKT ,欣赏支持了!!
1万
发表于 2010-4-13 21:44:10 | 显示全部楼层
:victory:很不错,欣赏支持了。
GMT+8, 2025-6-7 06:06 , Processed in 0.030466 second(s), 8 queries , Redis On.
