查看: 34252|回复: 1
[软件] M-Audio USB Quattro for Mac
6万
音频应用高级会员
Rank: 7Rank: 7Rank: 7
发表于 2010-4-1 13:48:01 | 显示全部楼层 |阅读模式
来自Mac App Store官方介绍* _( }3 m% e. x& @
+ n' J2 A+ x- U9 }. x. g; p! l8 B$ K0 c8 h
The Quattro USB audio interface is perfect for any application that requires portability and high-quality audio. It's designed to run on AC-power in order to drive the same high-end components found in the company's acclaimed Delta PCI audio card line.5 L1 ^7 x" f9 `% l, E* {
v1.6版本新功能
2 q) T! T* a) O1 N& k$ O7 m, q8 R" @
5 d" i4 h, P" ~$ C0 B; l0 w" J! H4 A$ X: D9 j4 G
Updated Release Driver for use with Mac OS X Tiger
1万
发表于 2010-4-1 15:36:54 | 显示全部楼层
支持…支持…支持
GMT+8, 2025-6-8 18:00 , Processed in 0.026207 second(s), 5 queries , Redis On.
