查看: 21633|回复: 2
[转载] Cinesamples Kalimba KONTAKT
2万
音频应用初级会员
Rank: 6Rank: 6
发表于 2010-1-28 09:23:48 | 显示全部楼层 |阅读模式
我们深入采样的非洲Kalimba具有各种各样的声音和音质以及直观的界面。世界大赛Kalimba脚本具有智能循环选择功能,可以尽可能多地改变性能。
我们抽取的Kalimba有17个齿;两个八度的C小调pentatonic与4重复齿,G3,Bb3,C4和Eb4。乐器在重复的尖齿之间切换并显示当前正在播放哪个尖齿。每个麦克风视角和FX层都可以路由到特定输出,从而实现更灵活的混音。 WANDER控制旋钮随机移动平移或单独改变音符的音高。从不同的冲动响应中选择添加REVERB。调整ADSR信封以塑造音符。 PAN LOCK统一了所有麦克风的平移。并且每个麦克风位置都可以路由到不同的Kontakt输出。
特征:
3个麦克风位置+ 1个FX层
17个单独采样的尖齿
记录有无蜂鸣器
多达10倍的RR和12个速度层
8个补丁
原文
Our deeply sampled African Kalimba features a wide variety of sounds and textures and an intuitive interface. The World Series Kalimba script feautres intelligent round robin selection, which forces as much variation in the performance as possible.
The Kalimba we sampled has 17 tines; two octaves of C minor pentatonic with 4 duplicate tines, G3, Bb3, C4 and Eb4. The instrument alternates between duplicate tines and shows which tine is currently being played. Each microphone perspective and the FX layer can be routed to specific outputs, allowing for more flexible mixing. The WANDER control randomly shifts the panning or alters the pitch of notes individually. Choose from different impulse responses to add REVERB. Adjust the ADSR Envelope to shape the notes. The PAN LOCK unifies the panning of all microphones. And each mic position can be routed to a different Kontakt output.
Features:
3 Microphone positions + 1 FX layer
17 individually sampled tines
Recorded both with and without buzzers
Up to 10x RR and 12 Velocity Layers
8 Patches
下载地址:
游客,如果您要查看本帖隐藏内容请回复
Cinesamples Kalimba KONTAKT | 6.93 Gb
9938
发表于 2010-1-28 09:30:06 | 显示全部楼层
Cinesamples Kalimba KONTAKT  :victory: :victory:
4万
音频应用初级会员
Rank: 6Rank: 6
发表于 2010-1-28 13:25:13 | 显示全部楼层
传好了:victory:
GMT+8, 2025-5-30 20:17 , Processed in 0.032134 second(s), 8 queries , Redis On.
