查看: 40711|回复: 0
[效果器] A-Designs 500 HR Rack 效果器
发表于 2009-11-26 13:57:55 | 显示全部楼层 |阅读模式
You are able to use the 500HR and A Designs module combinations in four basic ways:
1. Loaded with two preamps it becomes a dual channel Mic Pre
2. Loaded with two EQ’s it is a dual channel EQ
3. Loaded with one preamp and one EQ it is a complete pre/post EQ recording channel
4. Use one preamp and the EQ in the 500HR and bypass your pre on your guitar/bass/keyboard amplifier and have a totally different amp for any live situation!
Features:
- Compatible with all the A-Designs 500 series modules
- Internal regulated power supply w/ 48v phantom power
- Steel chassis construction
- LED 48v indicator
- Included power cord
Connections Two XLR Inputs, electronically balanced, Two XLR, electronically balanced
Power Requirements are100/120/230 VAC - 14W
DC Power Output / Channel is 140mA @ "16VDC
Dimensions are 19" x 1.75" x 8.25" [1RU]
Weight (empty) 6 lbs
GMT+8, 2025-7-19 03:01 , Processed in 0.023541 second(s), 7 queries , Redis On.
