查看: 22826|回复: 1
[音色] 【性感萨克斯】Embertone Sensual Saxophone KONTAKT
发表于 2009-6-16 16:49:08 | 显示全部楼层 |阅读模式
产品名称 :        【性感萨克斯】Embertone Sensual Saxophone KONTAKT
官网:http://embertone.com/instruments/sensualsax.php#1
Embertone Sensual Saxophone KONTAKT |     244 MB
  性感萨克斯Embertone是唯一的数字乐器,实际上可能会接近我的性感。而且现在我能和谐了!
- Sexy Sax Man
  有时候你只是想把它放进嘴里然后吹气。但当芦苇被磨损或你的手臂变得沉重,你的感官性质可以拖垮甚至炫耀的萨克斯管。像你这样摇摆的情人是干什么的?
  进入感官萨克斯管-数字解决方案,以SAX饱和。在开始时先挑逗一下耳朵的爱抚,然后在腰带下面放一张长长的纸条。在性感萨克斯的感伤背景下,你总会有一个与欢乐相呼应的夜晚的合适的伴奏。
"Sensual Sax from Embertone is the only digital instrument that might actually come close to matching my sex appeal. Plus now I can harmonize!"
-Sexy Sax Man
Sometimes you just want to put it in your mouth and blow. But when a reed gets worn or your arms get heavy, your sensual nature can outlast even the swankest saxophone. What's a swinging lover like you to do?
Enter Sensual Saxophone - the digital solution to sax saturation. Tease the sound at the start for a caress of the ear, and then blow a long note that busts below the belt. With the sentimental setting of sensual sax, you'll always have the right accompaniment for an evening that echoes with pleasure.
True sensual legato, true straight legato
Neighbor borrowing round robin option
Custom, genius Kontakt scripting by Andreas Lemke
Custom, genius design by Jim Kennedy
700+ recorded samples
262 MB installed
Download from Amazon S3, nothing fancy (we're broke too, man!)
Sample resolution: 48 Khz / 24 bit stereo
Kontakt 4.2 (Full Retail) is 32/64-bit, MAC/PC compatible
Note: Native Instruments Kontakt version 4.2 or later full retail versions required..
Note: Free Kontakt Player will only work for 30 minutes with this product. Full version required to remove this restriction.
Kontakt 4 runs as a stand-alone application, VST® or Audio Units plug-in, RTAS® under Pro Tools 7/8 . Minimum: Mac OS X® 10.4 / 10.5, G5 1.8 GHz or Intel Core Duo 1.66 GHz, 1 GB RAM or Windows® XP (32 Bit) or Windows Vista® (32/64 Bit), Pentium® or Athlon XP 1.4 GHz, 1 GB RAM. 2 GB of RAM or more is highly recommended!
1万
发表于 2009-6-16 21:12:42 | 显示全部楼层
【性感萨克斯】Embertone Sensual Saxophone KONTAKT  分享
GMT+8, 2025-5-31 11:59 , Processed in 0.026864 second(s), 7 queries , Redis On.
