  • reboard  2023-1-12 15:03
    TASCAM 宣布推出新的Sonicview 16XP 和 24XP 数字录音调音台
    TASCAM 发布 TASCAM Sonicview 系列带多环境触摸屏的数字录音和调音控制台,包含 Sonicview 16XP 和 Sonicview 24XP 两个型号。
    Tascam发布新的Sonicview系列带多环境触摸屏的数字录音和调音控制台,包含 Sonicview 16XP 和 Sonicview 24XP 两个型号,每个都具有内置的 32 位/96kHz 多通道 USB 音频接口功能,以及配备 Dante 的舞台接口箱,使 TASCAM Sonicview 数字录音兼调音台成为了巡回演出,安装,录音棚和广播的特别选择。
    Sonicview 16XP 和 Sonicview 24XP控制台
    两个控制台中较大的一个,Sonicview 24,具有 24 个电动通道推子和三个触摸屏。
    该系列有两个新控制台,Sonicview 16和Sonicview 24,前者提供 16 个物理输入通道和 100 毫米电动推子,后者提供 24 个。两个控制台均采用 Tascam 的 HDIA (High-Definition Instrumentation Architecture)话放,而 TASCAM Sonicview 24XP 提供了 24 个物理输入通道与 100 毫米电动推子和 Class 1 HDIA 话放。在内部,这两个型号的架构是相同的,有丰富的 44 个内部输入通道(40 个单声道和 2 个立体声通道),22 个灵活的输出总线,以及 L / ...查看全文
  • reboard  2023-1-12 14:26
    u-he Satin v1.3.2 MAC/LiNUX REGGED
    We took a journey back to the Golden Age of magnetic tape recording. We wanted to recreate all kinds of tape machines in software, from the ground up. After many months spent on research, measurement and on developing an architecture that would be flexible enough for the job, we knew we had nailed it... But we couldn't stop there: We added the old noise-reduction systems that were often (mis)used for timbral compression effects. Then more heads and a global feedback path, which made an uber-tape-delay and realistic 'one-shot' tape flanging possible. Users familiar with analogue recording gear should instantly feel at home with Satin, and digital afficionados will also learn to love the magic of tape – Satin invites you to explore and find out for yourself.
    https://u-he.com/products/satin/
    下载:
    • reboard  2023-1-12 14:01
      Audio Alchemist 宣布收购 Chameleon Labs模拟设备制造商
      • 1050851d1673272844-audio-alchemist-announces-acquisition-chameleon-labs-unnamed.png
      全球专业音频品牌管理公司 Audio Alchemist 的负责人 Marek Stycos 宣布收购 Chameleon Labs,Chameleon Labs 是一家优质但价格实惠的模拟设备制造商,其灵感来自 70 年代经典的英国前置放大器和压缩器。Chameleon Labs 成立于 2000 年代初,于 2014 年被资深音频电子设计师 Marcelo Vercelli 收购,Marcelo Vercelli 以开发 Event、Mackie、RCF 和 KV2 的创新产品和专利而闻名,Marcelo Vercelli 将公司的重点放在新一代产品上,包括旗舰产品 7603 前置放大器和 7721 立体声 VCA 压缩器。
      Audio Alchemist的负责人 Marek Stycos讲到:
      “Chameleon Labs 投入了两年时间和大量现金用于7602和7720的全面重新设计研发 ,由于分立 EQ、运算放大器、专有绕线输入和输出变压器、SMT 结构、经过审查的薄膜电阻器和定制内部通用电源等技术,这两款新产品现在都在完全不同的声波重量级中运行,为宽电压轨提供材料。这使Chameleon Labs 摆脱了模仿者的分类,进入了现代美国设计的编年史。”
      Chameleon Labs 7603 线路/麦克风/DI 前置放大器
      现任 Chameleon Labs LLC 和 Dangerous Music Group 总裁的Marek Stycos 继续说 ...查看全文
    • reboard  2023-1-12 11:15
      Loopcloud 推出Waves的Renaissance Reverb效果器插件免费下载
      Loopcloud 提供Waves 的Renaissance Reverb(99 美元)插件作为任何 Loopcloud 计划(包括免费试用)的免费赠品,直到 1 月 16 日。
      Renaissance Reverb是 Waves Audio 的算法混响插件。该插件提供了很大的灵活性,包括十二种混响类型和一个高级的早期反射发生器。
      Renaissance Reverb 不是专注于特定类型的混响,而是让你在不同的混响类型之间进行选择,包括 Halls、Rooms、Chambers、Churches、Plates、Reverse Reverb、Gated Reverb、Non-Linear Reverb、EchoVerb 和 ResoVerb。
      其他可自定义参数包括:在混响阻尼(Reverb Damping)、双频段均衡器、只需要简单地拖动图形上的节点,就可以改变混响的阻尼和均衡参数。用户如果不想在手动调整上浪费时间可以选择 Michael Brauer 和 Eddie Kramer 提供的预设。
      在下面的演示视频中快速浏览一下 Renaissance Reverb。
      youtobe 视频链接:https://youtu.be/wX370672nmc
      ...查看全文
    • reboard  2023-1-12 09:29
      Klotz AIS 目录开发新的连接器和线缆
      Klotz AIS开发了SmartBeam Dodeka 12,这是一个12倍透镜扩展光束连接器。FiberLink SmartBeam采用IP67材料,不受恶劣条件和污垢的影响。能够产生12x10GB/s 的传输速率,12根连接光纤(12x 50/125μm,OM4,多模)受到500μm初级涂层和900μm紧缓冲光纤的保护。它的直径为6.4毫米,方便在极端温度下快速卷绕。所有元器件也有单模提供(12x 9/125μm,OS2),与Fiberflex ULTRA F12US11A电缆组装在一起。单条信号链里允许混合使用不同的连接器,带有2、4、8 和12通道的SmartBeam连接器彼此兼容,并且与MIL-DTL-83526/20连接器兼容。可根据客户需求提供匹配的分线盒FiberExplorer。
      这家电缆制造商也将OmniFIX OX22GHB添加到其AES/EBU多芯系列中,以适用于模拟和数字音频信号。每对线具有2 x 0.22mm2的导体横截面,并配有箔屏蔽线对以及箔和致密编织双屏蔽。三重屏蔽和EN50575火焰测试确保OmniFIX不会受到干扰并且传输信号时保持低损耗。用于对和外护套的LSZH材料在发生火灾时不会释放有毒或含卤素的气体,并且烟雾很少。OX22GHB的箔屏蔽和对护套粘合在一起以加快处理速度。
    • reboard  2023-1-12 08:20
      Nureva与Extron集成,实现通过数百台先进摄像机进行声源定位追踪
      适用于Nureva HDL300系统的Extron®驱动器利用Microphone Mist™技术增强追踪性能。
      创新音频会议解决方案制造商Nureva公司1月10日荣幸宣布,旗下HDL300和Dual HDL300音频会议系统已与Extron控制和自动化解决方案集成,为用户带来支持混合式工作和学习的摄像追踪功能。Extron通过Nureva的声源定位设备API(可通过Nureva®开发者工具包获取)更新Extron控制系统驱动程序(Extron Control Systems Driver),Extron控制处理器接收来自HDL300和Dual HDL300系统的声源追踪数据,并通过发送预设的调用命令将摄像头平滑地转向说话人的位置。所提供的音源位置数据利用了Nureva专利的Microphone Mist™技术,该技术通过覆盖整个房间的数以千计的虚拟麦克风实现全方位的拾音,为现场和远程与会者带来清晰、稳定的音频体验。系统会每秒数次报告声源的方向、位置和电平,以便摄像机根据有源扬声器的位置进行自动调整。这项功能可以实现更精确的摄像头定位和切换,为远程与会者带来更好的体验。
      由于数百台先进摄像机集成了预设调用功能和Extron控制处理器,因此Nureva HDL300和Dual HDL3 ...查看全文
    GMT+8, 2025-7-20 20:00 , Processed in 0.018164 second(s), 7 queries , Redis On.
