Easy Audio Mixer 2.6.0 MacOS
Easy Audio Mixer Mac版是Mac平台上的一款简单易用的音频编辑工具。Easy Audio Mixer Mac版可以帮我们剪切音频,混合音频,从视频文件中分割音频,还可以将多个音频合并为一个。
软件特色
Easy Audio Mixer Mac版非常易于使用,只需要进行几次拖放操作,你就可以快速轻松地完成音频剪辑的工作。
支持几乎所有流行的音频格式,包括但不限于mp3,m4a,wav,wma等。支持几乎所有可以分割音频的流行视频格式,如mp4,wmv,rmvb等。
支持实时预览结果。支持音频切割,合并,分割和混音。支持音量调节,淡入/淡出效果。支持以mp3 / m4a / wav格式输出。
File size: 16 MB
Easy audio mixer is a simple audio editor tool and is easy to use. You can use it to cut audio, mix audio, split audio from video file, and also merge multi audios into one.
Key feature:
Support almost all popular audio format, including but not limited to mp3, m4a, wav, wma etc
Support almost all popular video format from which you can split audio, such as mp4, wmv, rmvb etc
Easy to use. You can quickly and easily finish the task by only a fe
...查看全文
