  • coastline  2021-5-20 16:40
    Steinberg WaveLab Elements 10.0.70 x64 WiN 母带处理软件
    通用音频编辑器Steinberg WaveLab是功能强大的工具,可用于专业编辑,音频文件的还原,高分辨率音频录音的编辑。该软件具有广泛的用户范围-从业余爱好者到唱片专业人士,并以最高的音质而著称。该编辑器在带有标准MIDI控制器(例如Steinberg CI,CMC和CC121)的64位Windows操作系统下工作。
    在功能方面,WaveLab超越了许多音频处理程序。该编辑器可进行音频文件的快速转换,包括批处理,创建备份副本和创建播放列表,开发音频CD和DVD的作者项目以及独特的功能,可在当时将音频效果添加到音频文件中播放。
    该程序的开放式体系结构使用户可以使用新的有用功能对其进行补充。
    斯坦伯格WaveLab Elements是WaveLab系列的核心产品,提供了一套令人印象深刻的仪器,这些仪器肯定会满足您的要求,同时无缝地集成到您的家庭工作室中。
    变更日志
    PAR-4746
    蒙太奇窗口的“编辑”选项卡中的“提示点”菜单现在始终处于启用状态(仅适用于WaveLab Elements / LE)。
    PAR-4744参考轨道的“增益/声像”设置现在可以正常工作。
    PAR-4743现在可以按预期进行音频蒙太奇中的撤消元数据编辑。
    PAR-4742
    在音频蒙太奇中使用Loudne ...查看全文
  • coastline  2021-5-20 16:19
    Download Steinberg WaveLab Elements 10 - Software edit and master audio, which is perfectly designed for the musician hobby, who work freely
    Steinberg WaveLab Elements:
    Steinberg WaveLab Elements is a software edit and master audio, which is perfectly designed for the musician hobby, who work freely on the radio, and studio owners at home. Based on the solution master WaveLab Pro has been approved, WaveLab Elements highlights the editing tools, and analysis has proven a valuable choice restoration and mastering plug-ins, tool CD recordings, and more - all accessible via the intuitive user interface.
    Steinberg WaveLab Elements introduced many improvements to make and edit workflows, as well as the features are carefully selected to refine and Polish the sound. Different from The edited spectrum leading to the plug-in new recovery technology unique Sound along with the plug-in is re-designed and advanced - WaveLab 9.5 is a leap in terms of sound quality.
    ...查看全文
  • coastline  2021-5-20 16:16
    Steinberg WaveLab Elements 10.0.70 Full Version
    MAZTERIZE May 03, 2021 💬 Comments
    Download Steinberg WaveLab Elements 10.0.70 Full Version
    Start Download (Tested)
    Steinberg WaveLabWaveLab Elements is a digital audio editor, recording and mastering software application that provides you a set of high quality tools. WaveLab is designed to meet and exceed the expectations of any home studio owners, hobby musicians, and other music enthusiasts who wants to get the best out of their audio. The program provides users with an affordable yet highly powerful set of high quality tools that covering all the basic tools and features needed for audio recording, editing, and mastering.
    Based on the WaveLab Pro mastering solution, the WaveLab Elements highlights proven editing and analysis tools, a valuable mastering and restoration plug-ins, a CD burning engine and much more. Steinberg WaveLab Elements provides numerous editing tools and support for many different file formats, ideal for simple mastering and audio editing jobs, and you can ...查看全文
  • coastline  2021-5-20 16:13
    Overview of Steinberg WaveLab Elements 10 Benefits
    Free Download Steinberg WaveLab Elements 10 full version standalone offline installer for Windows it is an audio editing and mastering software, perfectly tailored to hobby musicians, radio freelancers and home studio owners.
    You can also FREE download GoldWave
    Based on the approved WaveLab Pro mastering solution, the WaveLab Elements highlights proven editing and analysis tools, a valuable selection of restoration and mastering plug-ins, a CD burning engine and much more - all accessible through an intuitive user interface.
    WaveLab Pro introduces many improvements for mastering and editing workflows as well as carefully selected features for audio refinement and polishing. Ranging from a top-notch Spectrum Editor to the new restoration plug-in suite to the unique Audio Inpainting technology alongside a redesigned and enhanced plug-in set — WaveLab 9.5 is a quantum leap in audio quality.
    Overview of Steinberg WaveLab Elements 1 ...查看全文
  • coastline  2021-5-20 16:10
    Image-Line FL Studio Mobile v3.5.3 for Android 安卓版 手机版FL水果
    在Android手机或平板电脑上创建并保存完整的多轨音乐项目。录制,排序,编辑,混合和渲染完整的歌曲。
    功能:
    •高质量的合成器,采样器,鼓组和切片循环节拍器•
    步进音序器,用于快速打击乐编程
    •可配置的虚拟钢琴键盘和鼓板
    •兼容Class的MIDI控制器支持。演奏乐器并链接到旋钮/滑块
    •MIDI文件导入和导出(单音轨或多音轨)
    •录音,音轨长度/波形导入
    •浏览音高预览的样本和预设
    •平移,音量,释放和每台仪器可配置的起
    音时间•高质量音频引擎(输入/输出延迟取决于您的设备)
    •混音器:每轨静音,独奏,效果母线,声像和音量调节
    •效果包括:自动混音器,合唱,压缩器,限制器,失真,参数均衡器,图形均衡器,镶边,混响,高通/低通/带通/共振峰(Vox)滤波器,延迟器,移相器和立体声器可增强混音效果
    •钢琴卷帘窗编辑器可输入音符和弦或编辑录制的演奏
    •直观的屏幕布局可配置为与所有屏幕分辨率和尺寸配合使用。
    •保存并加载您的歌曲,导出到WAV和MP3
    •通过与其他Mobile 3设备/安装同步共享您的歌曲
    &# ...查看全文
  • coastline  2021-5-20 16:04
    Mac版 DJ软件-Algoriddim的djay Pro 应用程序和AI混​​音器
    djay-DJ应用程序和AI混​​音器。djay Pro的全新,现代界面基于与音乐库的精细集成而构建,可让您立即访问数百万首曲目。原始的音质和强大的功能集,包括现场制作工具,四个卡座,高清波形,视频混合和硬件集成,为您提供了无限的创作灵活性,可以重塑DJ装置。
    欢迎使用djay Pro AI!Algoriddim广受赞誉的DJ软件和多个Apple Design Awards的获得者已使用突破性的AI技术NEURAL MIX™从头开始重建。
    NEURAL MIX™允许您实时隔离您喜欢的曲目的乐器和acappellas,并重新定义创意混音的边界。您可以分别淡入淡出两首歌曲的鼓,低音线和旋律,将音频效果应用于音乐的各个组成部分,甚至在继续播放同一音轨的旋律的同时循环播放节拍。
    NEURAL MIX™
    •实时隔离人声,鼓,贝斯线和乐器
    •FX路由:将音频效果应用于音乐的各个组成部分(人声回声,和声滤波器,鼓混响等)
    •循环路由:循环拍子当同一首歌曲的旋律继续播放时,反之亦然
    •AI交叉淡入淡出:无缝地融合和交换鼓,贝斯线或两条音轨的人声
    •AI波形:并排查看每个音轨的人声,鼓和谐波波形•
    ...查看全文
  • coastline  2021-5-20 14:24
    FL Studio水果音乐制作软件操作心得与技巧分享
    关于FL Studio水果音乐制作软件的操作技巧,和实际使用时的经验心得,希望通过这篇关于FL Studio水果音乐制作软件的心得分享,给刚接触这款编曲软件的初学者提供一些有用的帮助及建议。
    你们是否也是音乐制作爱好者呢?如果是,那就仔细阅读文章收集对自己有帮助的操作技巧吧~~
    音乐编辑
    1. Plucked 不支持弯音。
    2. 在某些插件的控件上做自动控制不方便的时候可以试试 Dashboard。
    3. 按 F10 并转到常规设置, 可以更改撤销次数, 但是增加内存占用。
    4. 在通道活性表右侧的灯上右击可以选中通道, 单击则全选或单选。
    5. 按 F10 并转到常规设置, 取消自动选择链接模块复选框可以实现同时打开多个插件窗口。
    6. 步进音序器; 通道设置以及工程浏览器不支持从主界面中分离。
    7. 以 zip 方式保存工程时会保存所有已加载的采样。例如 FPC 以及一些用到的 SF2 音色库。
    8. 菜单栏帮助>关于可以查看 FL 的具体版本号以及版本区别. 34. Boobass不支持复音。
    9. 按 Scroll Lock 键启用 / 禁用所有编辑窗口的自动滚动。
    10. 在钢琴窗以及播放列表中分别按主键盘 1 2 3 可以分别缩放视图,按 4 包括全部。
    11. 硬件不佳的情况下录制 ...查看全文
GMT+8, 2025-5-31 01:11 , Processed in 0.019642 second(s), 7 queries , Redis On.
