Sound Radix POWAIR v1.1.2 WIN 声音压缩器插件
POWAIR 旨在成为更智能、更自然的声音压缩器。它是一个双级响度电平器/压缩器/限制器,由一种新颖的专有压缩引擎提供动力,提供比以往更大的透明度和控制力。
第一阶段是 K 加权响度调节器,非常适合调节画外音或自动调节不同音乐片段的音量。在第二个压缩阶段,POWAIR 使用创新的增益检测和降低引擎,能够以最小的失真和对源的自适应响应快速增益变化。
独特的 Punch 功能可以在起音阶段完全控制瞬态电平,从而可以在控制峰值电平的同时调整瞬态的长度。
在业界首创,POWAIR 具有自适应压缩功能,可保持平均压缩动作,增加强度和胶水,同时保持录音的自然动态。
POWAIR was designed to be a smarter, more natural sounding compressor. It’s a dual-stage loudness leveler / compressor / limiter powered by a novel, proprietary compression engine which provides greater transparency and control than ever before.
The first stage is a K-weighted loudness leveler, perfect for leveling a voice-over or auto-adjusting the level of different pieces of music. In its second compression stage, PO
...查看全文
