  • 7499220  2021-3-6 10:49
    罗德 RØDE Wireless GO II APP 使用攻略
    澳大利亚罗德麦克风于近期正式发布了最新升级的双通道无线麦克风系统 RØDE Wireless Go II,与此前畅销的 Wireless GO 拥有同样小巧的外形尺寸和广播级音质,在功能上也有着一系列的开创性突破。
    RØDE Wireless GO II 最重要的功能之一就是板载录音功能,它可以直接将音频录制在每台发射器上,为无线干扰和断频等情况提供录音备份。 板载录音可以通过 Wireless GO II 的配套应用程序 RØDE Central APP 开启,你可以通过 APP 进行麦克风的偏好设置,开启和停用某些功能,访问、优化和导出录音,并且更新固件。
    让我们来了解一下这个功能强大的 APP 吧:
    压缩录音与未压缩录音
    开启板载录音时,提供了两种不同的录音模式的选择,你可以通过 RØDE Central APP 进行更改:
    压缩录音:在此模式下,Wireless GO II 发射器以压缩格式录制音频。每台发射器可以存储超过 40 小时的压缩音频。请注意,这比 Wireless GO II 发布时所声明的储存超过 24 小时 ...查看全文
  • 7499220  2021-3-6 08:41
    Loopmasters Future Vibes MULTIFORMAT
    Loopmasters Future Vibes [MULTiFORMAT]
    Loopmasters presents Future Vibes, a forward thinking collection of shimmering future bass samples for use in your music 100% royalty-free. This one was created with the intention of bringing chart-quality sounds to you so you can spend more time writing and less time tweaking.
    This one comes packed with over 1 GB of content, with a large enough serving future bass sounds to ensure a great shelf life in your sample library. Future bass vocal samples, bass loops, drum one-shots for future bass, texture samples, drum fills and much more are all included and ready for immediate use in your productions.
    The included loops play out at 160bpm, making this collection perfect for future bass, melodic trap, future beats, halftime and other forward thinking bass music genres!
    Product Specifications
    [audio][/audio]
    Format: (MULTi-FORMAT)
    046 x Synth Loops
    034 x Vocal Loops
    033 x Synth Bass Loops
    022 x Full Drum Loops
    020 x Hi-Hat Loops
    014 x Drum Fi ...查看全文
