  • tenkey  2021-9-28 08:05
    Revealed Recordings Revealed Atmosphere Drones Vol. 2 WAV
    透露大气无人机卷。 2 是一个鼓舞人心的无人机、音景和纹理库,可以为您的曲目设置动画。
    里面有70架无人机,每架1.5-3分钟,按重点排序,总共150多分钟。
    随着揭示大气无人机卷。 2、你会发现一系列令人惊叹的故事讲述工具,从美丽的天堂到黑暗和令人不安的声音世界氛围,在你的曲目中创造一个新的深度和质感!
    展示你自己。
    透露大气无人机卷。 2 – 细节
    REV-ATMOSDRONE2 [70 个样本]
    70架无人机
    总无人机时间:153 分钟
    所有具有可辨别音高的声音都标有精确的 Key
    格式:48Khz / 24Bit Stereo PCM .wav 文件
    Revealed Atmosphere Drones Vol. 2 is an inspirational library of drones, soundscapes, and textures to animate your tracks.
    Inside there are 70 drones, each 1.5-3 minutes long, sorted by key, for a total of over 150 minutes.
    With Revealed Atmosphere Drones Vol. 2, you’ll find a stunning collection of storytelling tools of the beautiful and heavenly to the dark and disturbing sound world atmospheres to create a new level of depth and texture in your tracks ...查看全文
  • tenkey  2021-9-28 08:00
    Atomix VirtualDJ Pro 2021 Infinity 8.5.6646 WiN DJ软件
    一款非常好用的音频处理软件,其功能强大,用户使用后,可以在ShaderToy上发布的任何着色器挖掘其无限创意,另外还可以添加可视化,视频以获得炫酷的图形,相机覆盖等功能
    File size: 564 MB
    VirtualDJ is the application that DJs use when they want to use a computer to play their music. Because being a DJ is more than just pressing play, DJs cannot just use iTunes or Media Player to perform a mix. They need special controls like crossfaders, loops, effects, etc, in order to “mix” the songs. It is used by DJs to replace their turntables and CD players, and use digital music instead of vinyl and CDs.
    In the same way that the CD players used by DJs have more options than a regular Hi-Fi CD player, VirtualDJ has more options than a simple media player like iTunes. It lets you “mix” your songs, by playing two or more tracks at the same time, adjust their relative speed so that their tempo will match, apply effects like loops etc, and cros ...查看全文
  • tenkey  2021-9-28 07:51
    苹果发布面向macOS的Safari 15更新 包含新外观设计、改进标签组等
    苹果今天发布了适用于macOSBig Sur和macOSCatalina设备的Safari15,其中包含对将在今年晚些时候发布的macOSMonterey更新中出现的功能的支持。Safari15为Safari引入了新的外观,具有圆形的、更明确的标签和对透明度的支持,一个可以切换为开或关的紧凑标签栏选项,以及标签组。苹果对此次更新的说明如下。
    Safari15提供了更快的性能,更好的安全性,以及以下新功能:
    -标签组帮助你保存和组织你的标签,并在不同的设备上轻松访问它们。
    -重新设计的标签有着更圆的、更明确的外观,并且会自适应网页的颜色
    -紧凑的标签栏选项在屏幕上显示更多的网页内容
    -HTTPS升级后,自动将网站从HTTP切换到更安全的HTTPS。
    Safari15可以通过打开系统偏好界面并选择软件更新选项来下载。目前还没有关于macOSMonterey何时发布的消息,但它可能在10月与新的Mac一起出现,因为预计苹果将在今年秋天举行以Mac为重点的活动,首次推出新的14和16英寸MacBook Pro型号。
  • tenkey  2021-9-27 23:03
    如何改善Discord音量过小
    很多人在使用Discord等远端视讯会议软体的时候会发现麦克风有音量过小的问题,如果你已经购买了一支USB麦克风但声音却无法正常设定使用,请参考本文说明来协助你改善。
    会发生音量过小的原因,除了麦克风的收音距离需要拉之外,很可能是这些视讯软体都有内建自动控制输入音量的功能,导致了音讯装置输入音量过小的问题,解决方法很简单。
    首先,请打开打开您的 Discord 应用程式(同样适用于 Discord Online),点击萤幕左下角的使用者设定。
    在左边的栏位选择语音&视讯,在右边的栏位找到自动判定输入灵敏度的选项,并将功能关闭。
    接著请将白色的滑轨移动到最右边。
    并在下方将回音消除 降噪与自动增益控制的功能关闭。
    设定好之后,就可以关闭设定视窗。麦克风音量过低的问题就可以解决了!
  • tenkey  2021-9-27 22:48
    Lindell Audio 50 Series Bundle v1.0.1 macOS/PC
    将您的 DAW 转变为模拟桌面
    API 控制台、前置放大器和均衡器具有紧凑而强大的声音,使它们成为世界上最受欢迎的专业鼓、吉他、合成器等等,具有态度和存在感。得益于 Brainworx 的专利容差建模技术* (TMT),您现在可以访问这些经典控制台中最令人信服的模型,包括其模拟组件值的轻微通道间差异。在一个插件中
    具有
    72 个不同的 TMT(美国专利号 10,725,727)通道仿真,就像真正的控制台
    在 3 个不同 EQ 之间切换,模仿最流行的 500 系列午餐盒设计
    在 2 个不同的压缩器、VCA 和 FET 之间切换。
    模拟经典 API 噪声门和扩展器
    捕捉经典 API 前置放大器的完整、紧凑和有力的音调,具有自动增益补偿
    连续可变的 THD 和虚拟增益控件,以独立或全局添加彩色饱和度和/或模拟模拟噪声
    可扩展的 UI 以适应您的屏幕尺寸和工作流程
    加载了大量有用的预设,为您提供寻找声音的起点
