  • aurora  2022-6-18 14:21
    Yamaha YC-3B Tonewheel Organ VST3 v1.1.6.15 WiN (x64)
    YC-3B 是一种可再现音轮风琴声音的 VST 乐器。YC-3B 包含 64 种不同的预设声音程序,让您可以从这些预设声音程序中创建您原创的风琴音色。您还可以将原始风琴声音保存为 VST 预设。
    安装信息: 0)在最新的 Steinberg Elicenser 控制中心上安装
    Team VR b25 Elicenser 修复 – 或 TC Team Multi License Edition ELC 。1) 正常安装即可。2) 如果您希望 VST 预设显示在 Steinberg MediaBay 的出厂内容下,请将 YC-3B 文件夹复制并粘贴到此位置:C:\ProgramData\VST3 Presets\Yamaha Corporation VST3 不需要在其上正常工作它自己的,但非常好和方便。如果您还没有该文件夹,请在粘贴 YC-3B 文件夹之前创建它。最终文件夹应该是这个,包含所有预设:C:\ProgramData\VST3 Presets\Yamaha Corporation\YC-3B
    https://audioz.download/software/win/212483-download_yamaha-yc-3b-tonewheel-organ-vst3-v11615-x64.html
  • aurora  2022-6-18 14:20
    Digital Sound Factory E-MU Proteus Rack KONTAKT
    Digital Sound Factory E-MU Proteus Rack KONTAKT | 1.79 GB​
    The Proteus Rack Library was produced by the original E-MU sound and graphic designers. Starting with the original hardware sound samples, instruments are
    mapped and programmed to match the hardware sound modules. The powerful script programming integrates the hardware functionality to the software for the
    same great look and feel of the sound modules. Proteus Rack Library is compatible with all Mac and PC Digital Audio Workstations.
    This new sound library is not an update to the original Proteus Pack. The sound module synthesizers have been built from the ground up. Now designed for Native Instruments free Kontakt Player, the full version of Kontakt, Komplete, and Maschine. The instruments are seamlessly integrated and can be controlled by all NKS hardware.
    Includes Proteus 2000, Mo' Phatt, Virtuoso, Xtreme Lead-1, Planet Earth, and Vintage Pro with over 3,500 legacy sounds that will expand your imagination.
    "As an early ...查看全文
  • aurora  2022-6-18 11:55
    Arturia FX Collection 2022.6 CE-V.R Rev
    FX Collection 3
    Audio effects you’ll actually use
    26 essential audio production plugins offering musicians and producers the inspiring, musical, and pro-grade software tools they need to get creative with their mixing, combining unmatched vintage gear emulations with game-changing contemporary effects.
    included:
    Bus FORCE v1.2
    Chorus DIMENSION-D v1.3
    Chorus JUN-6 v1.3
    Comp DIODE-609 v1.2
    Comp FET-76 v1.5
    Comp TUBE-STA v1.5
    Comp VCA-65 v1.5
    Delay ETERNITY v1.5
    Delay MEMORY-BRIGADE v1.5
    Delay TAPE-201 v1.5
    Dist OPAMP-21 v1.0
    Dist TUBE-CULTURE v1.0
    Edx FRAGMENTS v1.1
    EQ SITRAL-295 v1.2
    Filter M12 v1.6
    Filter MINI v1.7
    Filter SEM v1.6
    Flanger BL-20 v1.3
    Phaser BI-TRON v1.3
    Pre 1973 v1.6
    Pre TridA v1.6
    Pre V76 v1.6
    Rev INTENSITY v1.4
    Rev PLATE-140 v1.5
    Rev SPRING-636 v1.4
    Tape MELLO-Fi v1.2
    https://www.arturia.com/products/software-effects/fx-collection/overview
    (Win64)
  • aurora  2022-6-18 11:45
    法国 digigram 发布全新广电级声卡 ALP222e & ALP222e-MIC
    Digigram 推出了 ALP-X 系列数字和模拟声卡,以取代VX系列声卡。首发的是 ALP222e 和 ALP222e-MIC,并将在 2022年推出更多型号。
    ALP222e
    ALP222e-MIC
    ALP222e 和 ALP222e-MIC 声卡都保留了 VX222 声卡的标志性功能——播放和录音的高音质(适用于 ALP222e-MIC 版本)和可靠的耐用设计。
    除了它们的参考功能外,ALP222e 和 ALP222e-MIC 还受益于新的技术以增强性能。纤薄的外形设计将增加灵活性,允许在各种 PC 上安装,保持 Windows 和 Linux 提供完整的驱动,实现系统的兼容性是其中的优势。
    ALP222e 是一张集多功能、轻薄的立体声声卡。Digigram 品牌有着众所周知十分强大的稳定性,而该声卡也完美的继承了该项优点。ALP-X 系列的新功能使 Digigram 能够满足全球行业,对可靠性和性能至关重要的所有声音敏感的需求,包括应急系统、关键接点的通信和 365/24/7 全天候运行响应。
    在接口方面,可用输入包括两个带24位/192kHz A/D转换器和可调模拟和数字增益的平衡模拟线电平、一个带硬件采样率转换器的AES3输入、AES11同步输入、字时钟同步输入和两个GPI。可用输出包括两个伺服平衡模拟线电平 ...查看全文
  • aurora  2022-6-18 11:07
    TC Electronic SCF Gold SE 金色限量版合唱/镶边效果踏板
    TC Electronic SCF Gold SE 合唱/镶边效果踏板限量版,它与 2021 年 12 月发布的普通黑色版SCF Gold 完全相同,只是采用了精美的金色外壳。
    最初于1976 年发布,是 TC Electronic 的第一款官方产品,已被世界各地的专业音乐家使用。该踏板的合唱效果非常适合电吉他、电贝司、键盘和人声。,也是合成器的完美搭档。它的输入增益控制功能可为任何乐器设置适当的增益电平,镶边效果也同样非常出色,堪称模拟 Bucket Brigade 调制效果的黄金标准。
    与较早前再版的普通黑色版本完全相同,SCF Gold SE 在三个方面有所改进:其一是原始电源已被改为现代标准的 9V 输入, 其二是对模拟前置放大器做了改动,现在可在低频中提供更多温暖和更多动态余量,允许可接入有源、高输出的低音乐器或合成器。最后是电源/低频振荡器的 LED 灯变的更大一些,以便用户能更清楚地查看踏板状态。
    请看 SCF Gold SE 的介绍视频 :https://youtu.be/DEr78mSADeI
