  • Andy雨暮  2020-5-3 17:28
    Riffstation Guitar Software Portable v1.5
    Riffstation(吉他扒带神器)是一款可以自动帮助你识别歌曲音频并将之变成和弦的音乐软件,虽然不是百分百准确不过大部分ok,从流行音乐到摇滚金属再到交响乐都能识别!这个是我们QQ下载为您分享的无需注册、无需安装的单文件绿色便携版!
    Riffstation Guitar Software - The ultimate practice app for guitarists and musicians on PC. A tool that will help you view the cords from your favorite songs and perform a variety of modifications to the track to extract the sounds you need.
    Music editing and production are certainly among the activities many users would like to get involved into, but they are much more difficult than they would seem at first glance. When it comes to working with specific musical instruments, things become even more complicated, but if playing the guitar is your hobby, for instance, then is worth taking a shot at using a tool like Riffstation.
    With a great looking interface and easy to use controls, this utility can surely help in analyzing and extracting song passages. The waveform view ...查看全文
    • Andy雨暮  2020-5-3 17:22
      (效果器)Antares Auto Tune 9
      Antares Auto Tune9中 是一款功能强大的音高修正软件,它主要是用于实时音高校正和效果的自动模式,以及用于详细音高和时间编辑的图形模式。下面小编准备好了破解教程,有需要的赶紧来下载吧!
      软件功能:
      1、可实时调节自然颤音2、比以前更大的音高编辑窗口3、可以跟着宿主的播放条走4、可选时钟源,与宿主的速度同步,或自己指定速度5、加入了靠近音符功能6、图形模式能显示演奏的音高包络,你可以用其提供的工具画出需要的音高.通过这种模式的控制,你可以修正和改正你想要得到的最想要表达的东西7、改进的音高探测算法,更加精确8、全新的界面9、统一的音高控制界面,把以前的两个自动窗口和图形窗口合二为一,而且可以实时显示出来10、人性化的调节功能,使调节后的声音不要过于的完美11、加入了清除所有数据功能,快速取消所有的移调12、如果你使用带触摸屏的平板电脑,就可以用真实的笔来画出移调曲线13、在图形模式下可以同时编辑多条音轨14、改进的音高探测算法,更加精确,而且把以前的两个自动窗口和图形窗口合二为一,方便操作。
      GMT+8, 2025-8-27 08:25 , Processed in 0.017785 second(s), 11 queries , Redis On.
