CubicSDR 0.2.0-beta-rc4 ·¢²¼ ¿çƽ̨ÒôƵӦÓÃ
CubicSDR 0.2.0-beta-rc4 ·¢²¼ÁË£¬CubicSDR ÊÇ¿çÆ½Ì¨µÄ¿ªÔ´ÒôƵӦÓã¬ÔÊÐíÄã²Ù×÷ÎÞÏßµçÆµÆ×ºÍ½âµ÷Äã¿ÉÄÜ·¢ÏÖµÄÈÎÒâÐźš£µ±Ç°°üÀ¨Ò»Ð©³£¹æÄ£Äâ½âµ÷ģʽ£¬±ÈÈç AM ºÍ FM£¬Î´À´»¹»áÖ§³ÖÊý×Öģʽ¡£
±¾´Î·¢²¼¸Ä½ø¼Ç¼ÈçÏ£º
Update SoapySDR to 0.5.x
Add flatpak build for Linux
Update SoapyAirspy with Bias Tee support
Minor SoapySDRPlay fixes
Using AppImage (Linux)
Run chmod +x CubicSDR.AppImage to make the file executable.
Run from shell ./CubicSDR.AppImage or double-click in file browser.
Using Flatpak (Linux)
Install flatpak using instructions from http://flatpak.org/getting.html
Install Gnome 3.20 runtime flatpak install gnome org.gnome.Platform 3.20
Install CubicSDR flatpak flatpak install --bundle CubicSDR.flatpak
Once installed, run with flatpak run com.cubicsdr.App
To uninstall CubicSDR flatpak (or prepare for re-install) flatpak uninstall com.cubicsdr.App
Included SoapySDR support modules
SoapyRemote
RTL-SDR
AirSpy
SDRPlay** (only AppImage supported for Linux currently)
HackRF
BladeRF
Red Pitaya
Audio Devices
UHD (OSX / Windows Only)
RFSpace (OSX Only)
ÏÂÔØµØÖ·£ºhttps://github.com/cjcliffe/CubicSDR/releases/tag/0.2.0-beta-rc4
»®Öصã:
CubicSDR 0.2.0-beta-rc4 ·¢²¼ ¿çƽ̨ÒôƵӦÓÃCubicSDR 0.2.0-beta-rc4 ·¢²¼ÁË£¬CubicSDR ÊÇ¿çÆ½Ì¨µÄ¿ªÔ´ÒôƵӦÓã¬ÔÊÐíÄã²Ù×÷ÎÞÏßµçÆµÆ×ºÍ½âµ÷Äã¿ÉÄÜ·¢ÏÖµÄÈÎÒâÐźš£µ±Ç°°üÀ¨Ò»Ð©³£¹æÄ£Äâ½âµ÷ģʽ£¬±ÈÈç AM ºÍ FM ...
