Side Menu
音频应用 首页 新闻资讯 查看内容
New Tool, Batch xFader, Automates Process Of Making Sample-Based Instruments
2022-8-16 09:35| 发布者: roar| 查看: 615| 评论: 0
摘要: New Tool, Batch xFader, Automates Process Of Making Sample-Based InstrumentsHomegrown Sounds has introduced Batch xFader, a new tool designed to automate the work of making sampler instruments out of ...
Homegrown Sounds has introduced Batch xFader, a new tool designed to automate the work of making sampler instruments out of samples.
This process generally involves:
Creating a sustain loop.
Cross fading the loop so it loops seamlessly.
Trimming any space at the start.
Or trimming all/most space at the start.
Creating a short fade in at the start to avoid any non zero-crossing clicks.
Deleting all data after the loop section which is not usually used.
Converting Stereo to Mono.
Convert to multiple Formats.
Batch xFader can quickly accomplish all of these tasks, as a batch process, on a folder of WAV files.
Pricing and Availability:
Batch xFader is available with the intro price of $19.99 until the end of August 2022 (normally $34.99). It is available for x64 Windows and as a Universal Binary for macOS.
https://youtu.be/J-rfBSKgNds
路过
雷人
握手
鲜花
鸡蛋
最新评论
原创月排行
原创周排行
最新回复
本周热议
发帖排行
