Lynx Aurora(n) - New modules
Input and output modules for Aurora(n) converter
Lynx Aurora(n) LM-A4 LM-A24 input output modules converter analogue digital ad da
Lynx have announced the LM-A4 and LM-A24, two new modules for their Aurora (n) converter that will be available for purchase later this year (2022).
The LM-4A is an output-only module that provides four balanced analogue outputs on TRS connectors, which Lynx say will make an excellent companion to their LM-PRE4 input module, allowing users with smaller studios and I/O requirements to configure a four input, four output Aurora (n). The LM-24A features two analogue inputs alongside four balanced analogue outputs, all present on TRS connectors. The inputs are switchable between +20 and +24dBu operating levels to offer compatibility with a range of professional equipment.
Quoted specifications for both modules are as follows:
Line Out (includes D - A Conversion)
THD+N: -108dB @1kHz, -1dBFS, 20kHz filter, +20dBu FS setting
Dynamic range: 120dB, A-weighted, -60dBFS signal method
Frequency response: ¡À0.025dB, 20¨C20kHz
Crosstalk: -130dB maximum @ 1kHz, -1dBFS signal
Output level: -71.5dBu to 24dBu, adjustable in 0.5dB increments in the analog domain
Connection: Electronically Balanced TRS
Line In (includes A - D Conversion) (LM-A24 only)
THD+N: -113dB @1kHz, -1dBFS, 20kHz filter, +20dBu trim
Dynamic range: 119dB, A-weighted, -60dBFS signal method
Frequency response: ¡À0.010dB, 20¨C20kHz
Common mode rejection: greater than 80dB
Full-scale trim settings: +20dBu, +24dBu
More information along with detailed specification sheets can be found on the Lynx website.
Suggested retail prices are $750 for the LM-A24, and $575 for the LM-A4.
https://www.lynxstudio.com/products/lm-a24/
»®Öصã:
Lynx Aurora(n) - New modulesInput and output modules for Aurora(n) converterLynx Aurora(n) LM-A4 LM-A24 input output modules converter analogue digital ad daLynx have announced the LM-A4 and LM-A24, t ...
