This TC Electronic SCF Gold SE Chorus/Flanger is a limited run, a special edition of the recently reissued BBD analogue modulation circuit.
The TC Electronic SCF Gold SE Chorus/Flanger * is going to be a limited run and so you may want to order one fairly soon or miss out on owning a gold shiny pedal. It is the exact same circuit as the regular black edition that was released in December 2021 just in a fancy gold case.
Gold Standard
It was originally released in 1976 and was TC Electronic¡¯s first official product and has a solid reputation, having been used by professional musicians all over the world.
The chorus is perfect for electric guitar, electric bass, keyboards and also vocals. The P.M. function harmonises very well with synths, too, and the flanger is section is glorious. Thanks to the input gain control, you can set just the right amount of gain for any instrument. It really is the gold standard of analogue Bucket Brigade modulation effects.
Gold Standard modulation
Limited Run
Pre-orders are open now and you can get this limited-run gold pedal from Thomann. Be sure to check out the demo videos below to hear this classic effect in action.
»®Öصã:
This TC Electronic SCF Gold SE Chorus/Flanger is a limited run, a special edition of the recently reissued BBD analogue modulation circuit.TC Electronic SCF Gold SE Chorus/FlangerThe TC Electronic SCF ...
