LFOH! audio/MIDI modulator effect for AUv3/iOS by K-Devices
Bringing the flagship LFO from the Modulators 21 Max For Live suite to iOS, K-Devices¡¯ new audio/MIDI modulator AUv3 plugin LFOH! enhances the possibilities of the classic cycling envelope by adding control over a set of advanced and unique features.
LFOH! is both an audio and a MIDI modulator. While it is capable to send its modulation signal out as MIDI CC (according to the MIDI routing flexibility of the app that hosts it), it can also modulate the amplitude of incoming audio.
LFOH! is a single oscillator LFO with a set of continuously morphable and selectable waveforms that represents the core of its modulation signal. Apart from the classic frequency and phase parameters, the waveform can also be shaped by swinging its cycles, bending its curve, squeezing portions of oscillation in the same period of time; it can be scaled and transformed while exceeding its boundaries. An additional sample and hold circuit provides quantization for the resulting signal.
LFOH! features
5 continuously morphable and selectable waveforms (sine, ramp down, triangle, ramp up, square) + noise.
A multitude of parameters to sculpt the modulator signal: phase, swing, bend, squeeze, transform (wrap, fold, clip), sample and hold, smooth.
MIDI only: scale, set channel and CC. Note that MIDI CC modulation depends on the MIDI routing flexibility of the host app.
Audio only: modulation amount.
Dark/light skin.
Available as an AUv3 plugin for iOS, LFOH! is on sale for the intro price of 1.99 USD/EUR until June 30th, 2022 (regular 3.99 USD/EUR). In celebration of the release, all K-Devices iOS apps are 50% off during the introductory promotion.
»®Öصã:
LFOH! audio/MIDI modulator effect for AUv3/iOS by K-DevicesBringing the flagship LFO from the Modulators 21 Max For Live suite to iOS, K-Devices¡¯ new audio/MIDI modulator AUv3 plugin LFOH! enhances t ...
