The "X" stands for transformer.
Unique, wideband frequency response with extended "air"
Harmonic saturation from transformer-coupled circuit
Designed, assembled, and tested in California
Includes our Cutaway shockmount and flight case
In stock for immediate shipment
The Mini K67x expands the promise of "sonic diversity" by introducing a new sound to the Mini K product line. The capsule voicing strikes a balance between neutrality and flattery, with tight bass and an open top end. The circuit enhances the source with harmonics. The mic retains the "point and shoot" simplicity of the Mini K lineup.
Like all Roswell microphones, the Mini K67x is designed, assembled, and tested in California.
CUSTOMER FEEDBACK FOR THE MINI K67X
The guitar player's lead tone was bad, so I had him send me DI solos to reamp. I tried my normal mic selection, as well as the Mini K67x. It won by a landslide.
This mic is the sound of rock and roll!
I really like the color and weight it has. The color doesn't take away from the clarity. It is definitely my favorite Mini K for vocals.
We are loving the 67x. Put me down for three more!
DESCRIPTION
The mic's name, "K67x," refers both to the capsule design and circuit topology. The capsule is based on the K67, although we've built and voiced it with some proprietary tricks to create a sound unlike any other K67 capsule. The "x" in the model name refers to the transformer-coupled circuit, which gives the mic its trademark harmonic saturation.
This combination introduces a new color to the Mini K product line. The mic is not overtly colored, like the Mini K47, nor is it quite as flat and neutral as the Mini K87. The sonic inspiration for this model was the workhorse tube mic of the 1960s, which offered wideband frequency response and harmonics. We kept those characteristics in this incarnation.
Every Roswell microphone is subjected to a 24-hr "burn in" on our proprietary conditioning fixture, then tested extensively prior to shipping: polarity, noise, frequency response, sensitivity, and more. We perform an acoustic sweep test and listen to every microphone multiple times before it leaves our facility.
The Mini K67x has a durable gray metallic paint finish. Each mic ships with our exclusive Cutaway™ shockmount, Roswell branded microfleece mic sock, and an upgraded flight case.
A limited quantity of the Mini K67x is in stock, ready for immediate shipping. We anticipate a delay in filling orders due to the popularity of the mic at launch. Because these microphones are assembled by hand, individually tested, and burned in, some initial orders might be delayed by 7-14 days (once initial inventory is depleted).
»®Öصã:
The "X" stands for transformer.Unique, wideband frequency response with extended "air"Harmonic saturation from transformer-coupled circuitDesigned, assembled, and tested in CaliforniaIncludes our Cuta ...
