Voice or Music
The Cloud 44-A is the first and only active ribbon microphone with switchable Voice/Music response curves.
Voice Setting
Instantly reduces the bass proximity effect associated with being close to the microphone. Reduces rumble and vibration.
Music Setting
Full bass response at close proximity for a variety of sources that require that special ribbon mic sound.
Made in the USA
Cloud Microphones are 100% Made in the USA.
Two year ribbon warranty and free limited
lifetime warranty on all other parts.
Specifications
Figure 8 polar pattern, excellent side null rejection
Frequency Response: 20 Hz to above 20 kHz
Maximum SPL: 138 + dB SPL above 1 kHz
Output Sensitivity: -28 dBv/Pa
Output Impedance (in Ohms): 150 ohms
Phantom Powered ¡°Cloudlifter¡± Class A, Discrete Circuity
Ribbon dimensions: .19" wide, 2.35" long, 1.8 microns thick
New mount offers 180 degree range of motion
Internally shock mounted
2 year ribbon warranty
Free limited lifetime warranty on all other parts
Handmade entirely in the USA
Dimensions: 7.75¡± x 3¡± x 1.75¡±
Weight: 1.07lbs
Recommended Load (in Ohms): 1kohm or greater
Supply Current: 4mA
Filter Frequency: 80Hz
Accessories: cover
Patents:  9,167,327;  9,210,508;  9,813,791;
9,888,315;  10,356,507;  10,721,552;  D605,637
*RCA is a registered trademark of Radio Corporation of America. References to RCA are historical in nature and imply no affiliation with Cloud Microphones.
Raise Your Voice
»®Öصã:
Voice or Music​The Cloud 44-A is the first and only active ribbon microphone with switchable Voice/Music response curves.Voice Setting​Instantly reduces the bass proximity effect associate ...
