CME MIDI Tools: MIDI Thru5 WC and WIDI Thru6 BT
MIDI Solutions MIDI Thru
The world's first MIDI Thru box with advanced wireless MIDI capabilities.
After the successful launch of WIDI technology, CME introduces a new branch of the WIDI family.
Finally, you can combine wired and wireless MIDI with 100% community-drive tools for studio, stage and mobile music making environments.
Meet the first two (2) members of the new hybrid MIDI family:
WIDI Thru6 BT with integrated Bluetooth MIDI
In essence, MIDI Thru5 WC delivers 1-in-5-out over DIN-5 wired ports and adds an optional expansion slot for WIDI Core.
At the same time, WIDI Thru6 BT goes one step further with its built-in WIDI capability.
Now you can access 2-in-6-out with a unique combination of wired and wireless, seamlessly breaking the barriers between your smart devices and MIDI hardware.
WIDI Core
Reserve Yours: 30% off Presale Program 2022
Now you can reserve your unit with a 30% discount and make sure you are the first to receive it.
By doing so, you streamline the first production run. If all goes well, you can expect delivery around the end of July 2022.
Due to current high fuel and international shipping rates, we are also exploring a partnership with Amazon to deliver locally at a much lower delivery cost. This applies to delivery in the EU and the US. Of course you can always order via our own webshop with worldwide delivery from Hong Kong.
Put yourself on the list, set your preferences and get exactly what you need, delivered to your door at the best price.
Please note there will only be a limited number of units available for this price. First come, first serve.
Pre-order Sign Up
General specification MIDI Thru5 WC & WIDI Thru6 BT
1-in / 5-out wired via DIN-5
Support all messages in the MIDI standard, including notes, controllers, clocks, sysex, MIDI timecode, MPE.
Wired transmission latency and jitter close to zero
Powered by standard 5V USB
MIDI devices with standard MIDI sockets are fully compatible
WIDI Thru6 BT
MIDI Thru5 WC
Build-in WIDI
Optional WIDI
1-in / 1-out via WIDI
Optional as expansion via WIDI Core
1-to-4 / 4-to-1 WIDI Group over 16 MIDI channels
2-in merge to 6-out through
1-in to 5-out through
Close to zero jitter and latency wired
Ultra low 3ms latency via onboard Bluetooth MIDI
Expansion slot for WIDI Core
Why do you need these hybrid MIDI Tools by CME?
Currently, there are two types of MIDI Thru products on the market. One was designed 5-10 years ago and the other was designed by non-professional manufacturers.
Technology has changed rapidly in recent years and today's chips are undoubtedly faster, more accurate, more energy efficient, smaller and cheaper. For reference, take a look at what your mobile device can do today and compare it to ten years ago.
Your MIDI setup can also benefit from this latest technology.
Most MIDI tools available work well for the most basic functions, but when the MIDI information you're transmitting is a little more complicated, these products can cause unwanted and hard-to-detect data errors.
The CME development team has more than 30 years of experience in developing MIDI products. Our devices are used and praised by top musicians and engineers around the world.
As a board member of the International MIDI Association, our team is on top of of the latest developments in MIDI. Including MPE, MIDI 2.0 and BLE MIDI.
Using the latest high-speed chipsets, available only since 2022, you now have access to the best performing MIDI technology available today.
In addition, the new suite of MIDI tools supports the most advanced Bluetooth MIDI technology via the in-house developed WIDI Core. Either built-in or optional and both for an insanely low price.
Sign up today and enjoy worry-free use for the next 10 years with innovations that meet all your professional needs with optimal performance and the lowest possible price.
MIDI Thru5 WC: The latest wired MIDI technology delivers extreme accuracy!
The only 1-in 5-out MIDI Thru and splitter box with expandable Bluetooth MIDI option
All MIDI messages appearing at the input are sent 100% to all five thru outputs
High-speed optocoupler for MIDI input to clean up the MIDI data and ensure accurate MIDI transfer
Support all MIDI channels and messages, let all your MIDI devices sync together
Power supply with general USB charger, battery power bank or USB hub
Latest fast processor, close to zero latency and no jitter, no bleeding midi, no signal dropout
Daisy chain multiple boxes to expand for larger systems
Compact, stable and reliable with hexagonal stiffener housing.
Just connect your MIDI controller or any device that transmits MIDI messages to the MIDI IN port, then connect the receiving MIDI devices to the MIDI Thru ports and you're all set!
Wired setup with MIDI Thru5 WC
WIDI Thru6 BT: Expand with premium Bluetooth MIDI technology!
Now you can get advanced wireless MIDI functionality with ultra-low 3ms latency by adding WIDI Core to your MIDI Thru5 WC. With over 50,000 units sold worldwide, WIDI provides a reliable and secure wireless MIDI connection for the studio and on stage.
There is, of course, a more simple solution. You can take advantage of all the wired benefits of the MIDI Thru5 WC, add the latest WIDI technology and be instantly satisfied with the WIDI Thru6 BT.
Connect EWI, motion controllers and smart MIDI devices of any brand. Pair your WIDI adapters and integrate Bluetooth MIDI directly into your ultra-fast wired MIDI setup.
Enjoy premium Bluetooth MIDI capabilities for connecting iOS, macOS, Windows, Android and other Bluetooth MIDI devices.
Register today and receive a 30% discount during the upcoming presale.
»®Öصã:
CME MIDI Tools: MIDI Thru5 WC and WIDI Thru6 BTMIDI Solutions MIDI ThruThe world's first MIDI Thru box with advanced wireless MIDI capabilities.After the successful launch of WIDI technology, CME intr ...
