OnyxGO | Mic
WIRELESS CLIP-ON MIC WITH COMPANION APP
OnyxGO | Mic is a completely self-contained wireless mic system for your smartphone. Just pair it, clip it on, and you are ready to rock. And with the OnyxGO app, you have a mobile content creation studio in your pocket.
CREATE ON THE GO
The app-powered OnyxGO | Mic is the best way to record your voice directly to your smartphone with amazing sound quality, versatility, and ultra-compact size. Just clip it on, open the OnyxGO app, pair it, and you¡¯re ready for action. Need video? It does that too. Whether you are recording a podcast, live streaming, or need to step up your quality for virtually any application, OnyxGO is here to make it incredibly easy to get clear, great-sounding audio into your devices.
Professional-quality built-in microphone
Connects to your mobile device via Bluetooth®
Ultra-compact design
Clips on to your shirt, jacket, sweater vest, etc.
Headphone output
Real-time stereo monitoring
Onyx preamp circuitry
Phone call recording
Noise reduction
Digitally mix Bluetooth audio and mic signal
Digital effects, 5 band EQ, reverb
Automatic lip sync
AI-powered auto-transcription & subtitle generation
CR-Buds Earphones included
»®Öصã:
OnyxGO | MicWIRELESS CLIP-ON MIC WITH COMPANION APPOnyxGO | Mic is a completely self-contained wireless mic system for your smartphone. Just pair it, clip it on, and you are ready to rock. And with th ...
