Smao Lab TaraTube Distortion
Free plug-ins: Smaolab TaraTube DistortionFrom the makers of Tarabia Distortion comes TaraTube, another unique and great-sounding distortion plug-in. TaraTube lets you choose the number of tubes in the signal path. This way, the plug-in delivers anything from soft saturation and enhancement to full-on tube distortion. There¡¯s also soft clipping, input and output gain controls, and a mix knob to dial in the desired amount of the effect. We¡¯re already looking forward to TaraLead ¨C another distortion plug-in the developer has in the works.
TaraTube Distortion is available for Windows and macOS in VST, VST3, and AU formats.
https://smaolab.org/tarabia-nation/#specifications
»®Öصã:
Smao Lab TaraTube DistortionFree plug-ins: Smaolab TaraTube DistortionFrom the makers of Tarabia Distortion comes TaraTube, another unique and great-sounding distortion plug-in. TaraTube lets you choo ...
