Audiomodern has introduced Panflow, a Creative Panning Modulator, designed to Shape complex, evolving panning patterns and add random, rhythmical movement to any audio track in real-time.
Panflow is designed to let you move sounds creatively, with precise stereo editing of panning modulation patterns.
Features:
VST/VST3/AU/AAX/iOS & Standalone
Generate Panning Motion in real-time
Syncs to Host tempo
MIDI Controllable
Infinity Mode
Quick Load presets
M1 Compatible
Instant/Tap Bypass for live performance
3 Curve modes
Customizable Sequence Range
MIDI Output
No Two Patterns will Ever be the Same
»®Öصã:
Audiomodern has introduced Panflow, a Creative Panning Modulator, designed to Shape complex, evolving panning patterns and add random, rhythmical movement to any audio track in real-time.Panflow is de ...
