Running Order 1U
Endorphin.es is really leaning into the 1U format and Running Order is the latest module to get the horizontal treatment. Running Order is a two-track trigger sequencer and Euclidean generator. It has the ability to run as a very precise master clock and clock divider and has incredible low jitter.
There¡¯s a very simple 101 style 1 step note input mode with manual or CV controllable trigger repeats. Alternatively, you can use Euclidean mode to set the total steps within the circle and then the number of triggers within it. You can add in probability for each step in 101 mode or do it globally in Euclidean mode.
You can sync and reset each track separately, although they are normalled when nothing else is plugged in and have individual mutes. The Clock divider section can mess with an incoming clock to find various divisions or in tuplet mode, it can stretch clocks to the desired amount of triggers for a bar. Finally, you can store up to 8 patterns for recall.
Endorphin.es Running Order 1U
A 3U version is also available but this 1U Running Order looks excellent to me. It¡¯s
»®Öصã:
The Endorphin.es Running Order gets a 1U twist while Airstreamer 4 gets a nice looping envelope update in a slimmer form.Running Order 1UEndorphin.es is really leaning into the 1U format and Running O ...
© °æÈ¨ËùÓÐ AI»ùµØ 2025,
