SynthIV Vibanez TL-V
Free plug-ins: SynthIV Vibanez TL-VHere¡¯s a nice and simple tremolo effect for your DAW, which is great on guitar, but also works on everything else. Clearly, the Vibanez TL-V plug-in by SynthIV emulates the Ibanez TL-5 tremolo effect pedal. The developer says that it recreates the original pedal design and stays faithful to the signal chain and principle of operation. Just like the original, the plug-in offers three controls for level, speed, and depth, as well as the bypass footswitch. Simple as that.
Vibanez TL-V is a VST3 plug-in for Windows.
»®Öصã:
SynthIV Vibanez TL-VFree plug-ins: SynthIV Vibanez TL-VHere¡¯s a nice and simple tremolo effect for your DAW, which is great on guitar, but also works on everything else. Clearly, the Vibanez TL-V plu ...
