Behringer RS-9 Eurorack ¹ÄÒôÐòÆ÷ºÏ³ÉÆ÷
»ùÓÚ Behringer RD-9 µÄÅÅÐòÒýÇæ²¢ÒýÈë Eurorack£¬Behringer ÏòÎÒÃÇչʾÁË×îÐ嵀 RS-9 Ô­ÐͲ¢ÎªÎÒÃÇÌṩÁ˸üС£
Based on the sequencing engine of the Behringer RD-9 and pulled into Eurorack, Behringer shows us the latest RS-9 prototype and gives us an update.
Behringer RS-9
We don¡¯t like to jump at every Behringer prototype but the RS-9 looks pretty interesting. We first saw the idea floated back in November 2020. Now it looks like it¡¯s going to become a reality. Behringer says that it still needs more time to finalise and test the module. The company has suggested a target price of $149.
The first thing to grasp is that the RS-9 is a drum sequencer, not a drum machine. It doesn¡¯t contain any of the RD-9 drum voices. Consequently, you¡¯ll have to plug it into other drum and percussion modules in order to get a sound.
Comparing the new photos with the original rendered image there have been a few changes. Mostly it seems like Behringer wanted to keep the buttons and functions the same as those used in the RD-9. That requires a little bit more space, so the branding has been relocated up to the top. A manual Trigger button has also been added.
Behringer RS-9
Connections
In terms of connections we have 10 trigger outputs with accompanying Accent outputs, Sync In/Out, MIDI In/Out on chunky 5-pin DIN and USB. There also appears to be a single CV input alongside a Reset input. Apparently, the buttons are not just for sequencing, you can also use them to trigger the channels manually.
On the whole, it¡¯s looking pretty snazzy.
User input
The comments under the Facebook post are very complimentary and Behringer is invited feedback. Some people are saying that the RD-9 buttons can be a bit stiff and are hoping these are a bit lighter on the touch. Others suggest adding a channel or two of CV output for running basslines or giving it the ability to load samples. Probability per step is probably more achievable.
»®Öصã:
Behringer RS-9 Eurorack ¹ÄÒôÐòÆ÷»ùÓÚ Behringer RD-9 µÄÅÅÐòÒýÇæ²¢ÒýÈë Eurorack£¬Behringer ÏòÎÒÃÇչʾÁË×îÐ嵀 RS-9 Ô­ÐͲ¢ÎªÎÒÃÇÌṩÁ˸üС£Based on the sequencing engine of the Behringer RD-9 and pulled ...
