Max for Live creator Dillon Bastan has created one of their best yet ¨C automatically using controllable Markov Chains to shift settings via Ableton Live¡¯s new Variations feature.
Dillon¡¯s been busy in the world of organic, creative processors for Ableton Live. For official Ableton Packs, there¡¯s Inspired by Nature, included free in Live 11 (definitely worth getting), plus the paid granular looping Iota instrument.
These free options are what I¡¯m diving into most at the moment, though. Markov Chains works by drawing on Live 11¡¯s Variations feature:
Detect Variations in a Rack on the same channel
Use Markov Chain probabilities to transition between them
Map a button to trigger new settings as you play, or detect transients, or set a time interval (with optional sync)
Control glide, transition time, bias, spray, intervals, and more
Demo:
And walkthrough:
Go grab it ¨C free or pay what you wish to support charity and send some gratitude to the developer. (Tip your patchers ¨C he donates 100% to various causes!).
Markov Variations
But wait ¨C there¡¯s more!
You¡¯ll find a ton of other wonderful free stuff, like the weird and interesting Fractal Filters.
And just¡ a ton more. I mean, go grab all of them, basically; don¡¯t sit here around CDM when you could be making sounds.
https://dillonbastan.gumroad.com/
»®Öصã:
Max for Live creator Dillon Bastan has created one of their best yet ¨C automatically using controllable Markov Chains to shift settings via Ableton Live¡¯s new Variations feature.Dillon¡¯s been busy ...
