Ginger Audio releases GroundControl Cube v2.0 - Adds tool for creating virtual audio drivers
Ginger Audio has released a major update for their free GroundControl Cube, now with a new tool for creating dedicated virtual audio drivers.
It can be used to route audio between applications running on your Mac. The user can easily create virtual audio drivers, name them, and set their cable count.
This is a useful tool for OBS - you can create drivers with unique names and use them in different scenes. For example, you can create a dedicated driver for Discord, a driver for Skype, Chrome, and so on. Then, you can simply choose them in OBS for each scene.
GroundControl Cube stays free, you can download it from: www.gingeraudio.com
»®Öصã:
Ginger Audio releases GroundControl Cube v2.0 - Adds tool for creating virtual audio driversGinger Audio has released a major update for their free GroundControl Cube, now with a new tool for creating ...
