SYNTH ANATOMY uses affiliation & partner programs (big red buttons) to finance a part of the activity. If you use these, you support the website. Thanks!
Sample Science has published Deep Jupiter, a new free bass virtual instrument VST/AU plugin for macOS and Windows featuring Roland Jupiter sampled synth basses.
Many musicians are happy when they can upgrade their sound arsenal for little money. Even more, if these new tools are free of charge. Today, I have a new plugin for you that you can download for free.
Deep Jupiter is the latest free virtual instrument release from Sample Science.
Sample Science Deep Jupiter
Deep Jupiter is a virtual bass instrument/module plugin that is based on samples. So it is not a whole synthesizer but a rompler-style plugin with sounds that you can use immediately without tweaking them for a long time. It features 8 multi-sampled raw bass patches for electronic genres like synthwave, chillwave retrowave, and synthpop. According to the developer, the internal samples/sounds are public domain.
The plugin also gives different options to shape the internal sounds. They are not very deep but good enough to give you a bit of sound demo playroom. It comes with a built-in switchable lowpass/highpass filter, a multi-wave LFO, an amplitude ADSR envelope, and glide control. Further, you get pan control and a decent-sounding internal reverb effect. The plugin can be played in monophonic, polyphonic, and legato mode. And Deep Jupiter is not a CPU hog, it¡¯s a very simple plugin that uses very little CPU.
Sounds like a nice free bass plugin. Not the most versatile but certainly a nice one that gives everyone vintage-inspired synth basses for free.
Sample Science Deep Jupiter is available now as a free download and runs as a 64-bit only VST and AU plugin on macOS and Windows.
»®Öصã:
SYNTH ANATOMY uses affiliation partner programs (big red buttons) to finance a part of the activity. If you use these, you support the website. Thanks!Sample Science has published Deep Jupiter, a new ...
