Home Audio Fidelity introduces its plugins suite for audio reproduction improvements
The acclaimed digital room correction service Home Audio Fidelity is expanding his offer by releasing new audio plugins. Improving sound reproduction is our ¡°raison d¡¯¨ºtre¡± and our plugins suite is addressing issues encountered with loudspeakers and Headphones:
Home Audio Fidelity introduces its plugins suite for audio reproduction improvements-rs.jpg
Room Shaper is the most advanced solution for loudspeakers & room correction in the low-medium frequency range. Thanks to innovative signal processing both clarity and impact are improved, and the room disappears!
More details in this presentation video
Home Audio Fidelity introduces its plugins suite for audio reproduction improvements-sosh.jpg
Soundstage Shaper revisits the old stereo shuffling concept and can be applied to both loudspeakers & Headphones. It is well known that intensity panning is not giving the same perceived position depending on the frequency content of the audio signal. Soundstage Shaper corrects this, and end user can optionally adapt the correction to its own hearing & speakers or Headphones configuration
Home Audio Fidelity introduces its plugins suite for audio reproduction improvements-hi-ai.jpg
Hifi Aid is bringing hearing aid to a hifi level: if you are just having hearing losses linked to aging or if you have specific deficiencies, this plugin will help to get back missing frequencies in a smart way. If you have your own audiogram, you can use it as input data
Link: https://www.homeaudiofidelity.com/english/plugins/
»®Öصã:
Home Audio Fidelity introduces its plugins suite for audio reproduction improvementsThe acclaimed digital room correction service Home Audio Fidelity is expanding his offer by releasing new audio plug ...
