MiniMix (Silver Panel)
Toppobrillo
Compact Stereo Mixer
The Toppobrillo MiniMix is a compact six-channel mixer , a pared-down cousin to the Stereomix. The workflow and interface (sliders!) takes heavy inspiration from the Buchla model 207, one of my favorite modular mixers, but is functionally a bit different. It's perfect for small/ travel cases, easily expandable has enough gain handy to work some outboard gear into the mix.
-Six main input channels, 4 mono and 2 stereo; stereo expansion inputs.
-Soft-mutes on each channel.
-VC "opposable" pan over channels 1 and 6.
-Up to +6dB gain and master level control.
-Loud and clean stereo headphone/ line driver with level control.
-Easily chainable with other MiniMix, Stereomix or other mixers.
-Extremely low noise/ low distortion design; higher-end opamps and audio grade caps used throughout.
Available for pre-order soon. Art subject to change.
submitted Wednesday August 18, 07:36 by toppobrillo | last Change Wednesday August 18, 22:13 by toppobrillo
»®Öصã:
MiniMix (Silver Panel)ToppobrilloCompact Stereo MixerThe Toppobrillo MiniMix is a compact six-channel mixer , a pared-down cousin to the Stereomix. The workflow and interface (sliders!) takes heavy in ...
