Free Max For Live Instrument, Spectral Shiatsu, Lets You ¡®Massage¡¯ Sound
Sensel, the creators of the Morph multi-touch controller, today introduced Spectral Shiatsu, a free instrument for Max For Live that lets you ¡®massage¡¯ sounds.
Spectral Shiatsu uses the Morph¡¯s ability to detect touch and pressure to give you a new way to interact with sounds. If you don¡¯t have a Morph, you can use Spectral Shiatsu with a mouse or touchpad.
Here¡¯s how it works:
When you load a sound file (or picture) into Spectral Shiatsu, it analyses it and creates a map of all the frequencies and their volumes over time.
This sonograph is then mapped to the Sensel Morph, so you can ¡®massage¡¯ the sound, pressing softly to play a small part or harder to play more of it.
¡°Artists and designers are all quite familiar with ¡®massaging¡¯ and ¡®teasing¡¯ their work,¡± says Sensel¡¯s Peter Nyboer, ¡°so we found a way to make this metaphor literal. You will definitely uncover some really unusual sonic textures, possibly even learning something about the nature of time and sound.¡±
Here are some examples of Spectral Shiatsu in action:
»®Öصã:
Free Max For Live Instrument, Spectral Shiatsu, Lets You ¡®Massage¡¯ SoundSensel, the creators of the Morph multi-touch controller, today introduced Spectral Shiatsu, a free instrument for Max For Liv ...
