Get Parallel Aggressor From BABY Audio
BABY Audio joins Bitwig Circle with a great offer for Bitwig creators: Get their Parallel Aggressor plug-in for free (worth $49).
BABY Audio is a young plug-in manufacturer with a team from all around the world. They describe themselves as "a collective of passionate optimists with wildly different musical preferences and diverse life backgrounds, united by a joy for creating audio products and researching new technologies." In other words, they¡¯re a perfect match for us!
Parallel processing plays a fundamental part in getting a "big" mix sound. By processing multiple copies of the same track and blending them together you can add more punch to a mix ¨C in a more natural-sounding way. Parallel Aggressor is based on this simple concept.
The plug-in splits your audio into three equal copies that can be processed separately to squeeze out every drop of sonic juice from your track. Parallel Aggressor comes loaded with 25 presets created by BABY Audio and some notable friends.
Parallel Aggressor loads seamlessly as a VST or VST3 plug-in in any project in Bitwig Studio, and it's compatible with macOS or Windows.
Log in to your Bitwig account to claim your plug-in. Once that's done, we highly recommend that you check out BABY Audio's whole line of plug-ins, because there are some real gems in there.
»®Öصã:
Get Parallel Aggressor From BABY AudioBABY Audio joins Bitwig Circle with a great offer for Bitwig creators: Get their Parallel Aggressor plug-in for free (worth $49).BABY Audio is a young plug-in man ...
