Phuturetone GR-8, new free virtual analog synth plugin for macOS & Windows
SYNTH ANATOMY uses affiliation & partner programs (big red buttons) to finance a part of the activity. If you use these, you support the website. Thanks!
Phuturetone has released for the KVR Developer Challenge 2021 GR-8, a new free virtual analog Synthesizer plugin for macOS & Windows.
And here comes another nice development by an indie company for the KVR Developer Challenge 2021. As a reminder, this is an event of the KVR Audio Forum where developers are invited to develop free plugins.
Phuturetone has a new Synthesizer on the start for macOS and Windows.
Phuturetone GR-8
Phuturetone GR-8
The GR-8 is a very classic Synthesizer. It uses an 8-voice virtual analog engine and is somewhat reminiscent of the look of vintage Roland synths. You can play it in mono, unison with 8 voices, chord (4 stereo notes), or in poly with 8 voices. Additionally, you have voice effects such as glide, legato, voice detune, and more.
GR-8 has two analog-style oscillators. Oscillator 1 has tri, saw, pulse, and square, oscillator 2 sine, saw, pulse, and noise. Three different oscillator effects are available including cross mod (FM), pulse width modulation (PWM), and sync. The x-mod exudes some Roland vintage charm again.
Then, you get a resonant lowpass filter with three slops (12, 18, or 24dB/oct) and a non-resonant highpass filter. The modulations can be routed instantly in the respective section (osc, filter¡). The synth is very hands-on and does not have a modulation matrix. This should allow you to build sounds quickly.
Phuturetone GR-8
Since we are already on modulations, GR-8 has a single multi-wave LFO, two ADSR envelopes, a pitch bender, and a mod wheel. You can route the LFO/envelopes to the filter, amp but also to the pitch. To refine your sounds, it also hosts a multi-effect processor with an EQ, distortion, phaser, chorus/flanger, delay, and reverb. Further, it features an arpeggiator with 5 modes and with a 4 octaves range.
First Impression
I downloaded it briefly and checked it. Sounds solid to me and a nice interface to play with. However, it currently uses a lot of CPU and the supplied presets do not stand out. But I¡¯m pretty sure we get many more presets from the community. Hopefully, the synth will get new features in the future and the developer finds a way to optimize the engine. So it can be a nice free synth.
Phuturetone GR-8 is available now as a free download as part of the KVR Developer Challenge 2021. It runs as a VST3 and AU plugin on macOS and Windows.
»®Öصã:
Phuturetone GR-8, new free virtual analog synth plugin for macOS WindowsSYNTH ANATOMY uses affiliation partner programs (big red buttons) to finance a part of the activity. If you use these, you sup ...
