音频应用 首页 新闻资讯 查看内容
Soyuz Microphones Introduces The 017 Series: Brass Black Limited Edition
2021-7-9 08:08| 发布者: 7621260| 查看: 683| 评论: 0
摘要: The hometown of Soyuz, Tula, has a tradition of metallurgy dating back centuries. Local iron ore attracted craftsmen, who soon gained a reputation for the finest samovars in the Russian Empire. Where ...
The hometown of Soyuz, Tula, has a tradition of metallurgy dating back centuries. Local iron ore attracted craftsmen, who soon gained a reputation for the finest samovars in the Russian Empire. Where there are blacksmiths, there are guns. Soon Tula became a center of, not only plowshares, but swords. Then guns, then tanks, then missiles.
At Soyuz, we take pride in having re-directed the world-class skills of master machinists from local weapons factories into the manufacture of our world-class microphones. As a nod to the city’s military past, we are proud to introduce the Brass Black series, created by using a technique called bluing to treat the brass.
Traditionally used to protect steel firearms from rust, bluing gives our mics an original and timeless finish that will highlight this version of the 017 Tube and 017 FET as the centerpiece of any mic locker.
THE 017 Tube: BRASS BLACK – Limited to 20 Mics
As our flagship mic, the 017 Tube has earned a reputation for its rich, lush, and timeless sound that will deliver a finished quality to any recording. The custom hand-machined capsule, toroidal transformer, and 6ZH1p tube provide the perfect combination of depth
Only 20 Brass Black 017 TUBES were made and have been divided across the world.
THE 017 FET: Brass Black – Limited to 25 Mics
The 017 FET represents the modern embodiment of the big, classic sound so highly prized in vintage microphones. Using the same capsule as its tube sibling, the 017 FET is a bit snappier in response and articulation making it perfect for applications like voiceover or sources where you want to capture extra nuance and detail.
Only 25 Brass Black editions were made.
Reserve Yours While They Last: https://soyuzmicrophones.com/article...es-brass-black
路过
雷人
握手
鲜花
鸡蛋
最新评论
GMT+8, 2025-7-2 04:03 , Processed in 0.021508 second(s), 10 queries , Redis On.
