音频应用 首页 新闻资讯 查看内容
Arturia announces limited-run black editions for entire Step range
2021-7-9 07:32| 发布者: 32030910| 查看: 562| 评论: 0
摘要: Arturia announces limited-run black editions for entire Step rangeArturia goes dark mode with limited-run black editions for entire Step rangeFrom finger drummers to keyboardists down the Eurorack rab ...
From finger drummers to keyboardists down the Eurorack rabbit hole, there’s a Step for every application, style, and ability. Get creative with instant sequencing and arpeggiation, make beats with effortless controls, and hook up your entire rig in perfect sync.
These are the Steps, designed to let you perform, improvise, write, and create with stealthy accuracy - out now while stocks last. Contact your nearest dealer for availability.
Keystep
Compact Sequencing Keyboard
A polyphonic sequencer and arpeggiator in the familiar form of a portable, highly-creative keyboard, perfect for controlling everything from softsynths to modular racks.
Keystep 37
Creative Idea Generator
A flexible 37-note keyboard with intuitive sequencing, instant chord generation, real-time MIDI controls, scale quantisation, and more - the perfect tool for musical discovery.
Keystep Pro
Universal Sequencing Mastermind
The all-in-one sequencing and performance controller, with 4 tracks, a dedicated drum sequencer, and all-encompassing connectivity - control anything.
BeatStep
Portable Pad Controller
An ultra-compact controller with deceptively advanced MIDI, CV, and DAW control capabilities, including mapped controls and instant scale quantisation
BeatStep Pro
Beat Making Powerhouse
The BeatStep formula expanded into a supreme multi-faceted controller, with projects, multiple 64-step sequencer tracks, 8 individual drum CV gate outputs, and much more.
For more information: https://www.arturia.com/step-black-range
路过
雷人
握手
鲜花
鸡蛋
最新评论
GMT+8, 2025-7-2 03:15 , Processed in 0.032464 second(s), 12 queries , Redis On.
