A thick ensemble chorus, with a multi-stage design producing a dense cloud of echoes, giving you a smooth detuning even at extreme settings.
The phasiness control lets you slide between two detuning modes. Blending these together gives a rich and lively sound (particularly for low frequencies) - or try higher values for something less conventional.
The attack control uses envelope-followers to reduce or boost the detuning when an attack is detected. Give your attacks a little extra twang, or keep them clean and clear.
Depth and detuning are controlled independently - and because Cloud Chorus has dense echoes, depth goes up to 100ms for something between a diffuse slap-back and a small (detuned) room.
»®Öصã:
A thick ensemble chorus, with a multi-stage design producing a dense cloud of echoes, giving you a smooth detuning even at extreme settings.The phasiness control lets you slide between two detuning mo ...
