Apple M1 Vs Apple Intel MacBook Pro - Compared For Audio Applications
We are yet to see many reliable direct comparisons between audio software running natively on Apple Silicon and the same software running on an Intel powered computer. Software developer Guillaume Jeulin from Blue Cat Audio has published his tests on his The Dark Side Of The Cat blog and with his permission we are publishing a detailed summary here. Over to you Guillaume¡
The new Apple M1 Macs have been available for a few months now, and the new M1 processor has been reported to bring huge performance gains for multiple CPU benchmarks.
Raw CPU performance is one thing, but now do these new machines perform with real time audio? Do they really perform better than Intel Macs?
We have tested the latest previews of two of Blue Cat Audio¡¯s flagship products, Axiom and PatchWork, optimised for both Intel and Apple Silicon (M1) processors. Let¡¯s see what the tests revealed!
Hardware Configurations And Test Conditions
The machines used for the benchmark are top of the line 13 inch Apple MacBook Pro computers¡
Apple M1 MacBook Pro (2021) with 16 GB RAM, 4 ¡°high perf¡± CPU cores, and 4 ¡°high efficiency¡± cores.
Intel Core i7 MacBook Pro (Late 2020) with 32 GB RAM), 4 CPU cores & Hyperthreading.
Both machines are running the latest versions of the macOS that they were delivered with: the M1 is running the latest iteration of Mac OS Big Sur, while the Intel is running the latest iteration of MacOS Catalina.
All tests were performed at 44.1 kHz, with an RME Babyface Pro FS audio interface (that provides native Apple M1 drivers).
Note: no third party host application nor plug-in was used during these tests: we have been running PatchWork or Axiom as standalone applications or loaded as plug-ins inside of of them. They both contain a wide variety of built-in effects with very different algorithms, so they are good candidates for such performance tests. The latest previews also offer a multicore mode, so both single and multicore performance could be tested.
About the Apple M1: the new M1 processor (¡°Apple Silicon¡±) has an entirely new architecture based on ARM cores, using different instructions than the Intel x86 processors. On an M1 Mac you can either run native Apple Silicon applications optimized for this processor, or run applications that were originally created for an Intel processor. In this case, the Rosetta 2 software translates the Intel instructions into ARM instructions that can be understood by the new processor. So it is not optimal but lets you run older software that was not rebuilt for the new architecture.
In order to record or play music live with a computer, you want to be able to process audio at lowest possible latencies with no audio dropouts.
Lowest Latency Without Dropouts
For our first test, we have loaded a ¡°standard¡± Axiom preset (with an amp and a few effects) and reduced the latency until audio drop outs started to occur:
With the M1 processor, either using Rosetta 2 or running natively the lowest latency we could go down to was 2.7ms. We actually reached the limits of the audio interface latency before any single dropout could be heard, which means that the machine is not the limit!
Single Vs Multicore Preset
On the Intel Mac however, while the average CPU usage was still quite low, audio dropouts would occur at latencies lower than 3.2 ms.
At this lowest possible latency, we measured the CPU usage (with the CPU workload meter built into the applications) on both machines:
Even at a lower latency (2.7ms vs 3.2ms), the Apple M1 is faster than the Intel Mac, either in native mode or when running thru the Rosetta translator.
As expected, we can also see that the native Apple M1 software runs much faster than the Intel version running through Rosetta 2 on the M1, so it¡¯s definitely worth using the native Apple M1 versions when possible.
Max Number of Instances
Still at the same lowest latency, the Patchwork application was used to load several instances of Axiom in parallel chains (all with the same ¡°standard¡± preset) to see how many could be running at the same time before getting audio dropouts.
What we found was that we could load twice as many instances on the Apple M1 machine, in both single and multi core modes, even at a lower latency!
Low Latency Tests @128 samples (8 ms)
To strictly compare Apples with apples (pun intended¡), let¡¯s see how they compare with the same latency, with a bit of headroom. The exact same tests were performed with 8 ms latency:
We observed that the M1 is much faster than the Intel Mac and can process more instances of the same plug-in, even when running the Intel app though Rosetta.
The performance gain is particularly impressive on a single core, with almost 3 times more plug-ins loaded (vs almost +50% on multiple cores) and the results were confirmed at higher latencies.
Other Observations
Fan Noise: Another thing that we noticed during the stress tests is that while the Intel Mac fans would kick in pretty quickly, the M1 Mac would stay cool, and we are still to hear any fan noise yet! This M1 machine is dead quiet, which is really appreciated when working with audio!
SSD Speed: It also seems that the accessing the SSD is much faster too: loading plug-ins is very fast, even when the user interfaces load many graphics resources.
Graphics Performance: Last but not least, graphical user interface performance seems to be improved a lot too: a quick look at the CPU and GPU usage in the activity monitor seems to confirm that it uses much less resources.
Conclusion
The new Apple M1 Macs are definitely winners for real time audio processing: when running in native mode, they greatly outperform the most recent Intel Macs, with absolutely no fan noise!
And even if you really have to run older apps and plug-ins that have not been optimized for the M1 processor yet, it may still run faster!
So if you still have a doubt that laptops with software can replace high-end hardware audio processors, try these new Apple Silicon Macs: they are simply incredible for this job!
Want To Know More?
Check out the original article on The Dark Side Of The Cat, where you will be able to see the detailed tables listing the results for each of the tests.
You can also listen to a discussion on Apple Silicon and pro-audio applications with Guillaume Jeulin from Blue Cat Audio and Matt Hill from Liquidsonics in our podcast Apple Silicon - Developing Audio Software For The New macOS.
»®Öصã:
Apple M1 Vs Apple Intel MacBook Pro - Compared For Audio ApplicationsWe are yet to see many reliable direct comparisons between audio software running natively on Apple Silicon and the same software r ...
