Super easy to play, highly realistic, and wonderfully expressive!
EASY THEREMIN features 22 authentic voices based on Theremin samples. The library allows you to perform volume swells, pitch glides, and emotional vibrato with intuitive controls.
Create expressive melodies with stunning human voice emulations. Add authentic 50s Sci-Fi sounds to your tracks and explore unique modern effects. This hypnotic instrument is capable of expressing extreme beauty and emotions!
• Voice menu with 22 Theremin voices.
• 3 main patches and 18 sound presets.
• 240 samples (mono and stereo WAV, 24bit, 48kHz).
• 13 custom IRs (spring reverbs, concert hall IRs, real room IRs¡­).
• Total size uncompressed: 122MB.
• Requires full version of Kontakt 5.8 or higher.
• Samples recorded on a Moog Etherwave Pro by French Thereminist HYrtis
!!! -50% introductory discount until July 31st
»®Öصã:
Super easy to play, highly realistic, and wonderfully expressive!EASY THEREMIN features 22 authentic voices based on Theremin samples. The library allows you to perform volume swells, pitch glides, an ...
