BLEASS Granulizer & Slow Machine, now available as VST3 & AU plugins.
SYNTH ANATOMY uses affiliation & partner programs (big red buttons) to finance a part of the activity. If you use these, you support the website. Thanks!
BLEASS Granulizer a granular effect, and Slow Machine tape stop and slow down effect, initially introduced on iOS now landed on macOS and Windows.
Vianney from BLEASS is one of the most talented iOS developers, in my opinion. His apps were all able to score with a very intuitive interface and great sound. The developers recently ported the first apps to the big computers as VST3 and AU plugins.
Two other apps, Granulizer and Slow Machine, have now also made it to macOS and Windows.
BLEASS Granulizer Slow Machine
BLEASS Granulizer
Granulizer is a granular effect plugin that generates short sample snippets (grains) from different input signals by modulating different parameters. Handy, all this is visualized in the plugin. It supports up to 4 sources from different busses as inputs. When multiple busses are on, each grain is randomly extracted from one of the available sources. With this sound design technique, you can generate very atmospheric sounds, especially in combination with delay and reverb.
BLEASS Slow Machine
Slow Machine is a tape stop and slow down effect plugin that can deepen andy beat by completely or partially slowing down the audio signal. The plugin works great to create tape stop effects with precission.
A nice release that shows that iOS apps can move also on macOS and Windows.
BLEASS Granulizer is available now for an introductory price of $30 USD (25% OFF) until July 14th, 2021. BLEASS Slow Machine for $12 USD (reg. $15 USD) until July 11th, 2021. Both plugins are exclusively available at Plugin Boutique.
»®Öصã:
BLEASS Granulizer Slow Machine, now available as VST3 AU plugins.SYNTH ANATOMY uses affiliation partner programs (big red buttons) to finance a part of the activity. If you use these, you support t ...
