SNFK Music releases SK100 free dual stereo buss compressor plugin
SNFK Music has announced the release of the SK100 plugin, a free dual stereo buss compressor effect for Windows and macOS.
The plugin includes two compressor models. Comp1 delivers harder compression, using peaking algorithms to instantly detect gain changes. It is designed to work well on many instruments, especially drums. Comp2 is a softer, glue-like compressor for more transparent corrections.
Each of the models has controls for threshold, ratio, attack and release, as well as input and output gain. The VU meter in the middle of the interface shows the gain difference between the input and output for each of the compressor models, or both at the same time.
The plugin is free to download from the SNFK Patreon page.
»®Öصã:
SNFK Music releases SK100 free dual stereo buss compressor pluginSNFK Music has announced the release of the SK100 plugin, a free dual stereo buss compressor effect for Windows and macOS.The plugin in ...
